No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35081
Background
The Craftsman Chain Saw 358.350810 is a gasoline-powered tool designed for cutting wood. It is fitted with a 2.4 cubic inch/40cc 2-cycle engine and an 18-inch bar, making it suitable for occasional use. The chain saw features several controls and adjustments for different functions. The ON/STOP switch is used to stop the engine while the throttle trigger controls the engine's speed. The device also has a throttle lock-out that must be pressed before the throttle trigger can be squeezed, preventing accidental activation.
The Craftsman Chain Saw 358.350810 is also equipped with a choke/fast idle lever, which is pulled out to the full extent for cold starting or after refueling to provide additional fuel to the engine. The primer bulb circulates fuel to the carburetor for quicker starting. The chain brake, a device designed to stop the chain if a kickback occurs, activates automatically in the event of kickback and manually if the front hand guard is pushed forward. Chain tension can be checked frequently and adjusted as needed, particularly as it is normal for a new chain to stretch during the first 15 minutes of operation. The chain saw is also designed with a muffler and spark arresting screen, which need to be regularly cleaned to avoid creating a fire hazard or affecting engine performance.
Technical Specifications
  • Model Number: 358.350810
  • Product Type: Chain Saw
  • Engine: 2.4 cu.in./40cc 2-Cycle GASOLINE engine
  • Bar Length: 18 in.
  • Chain Brake: Yes
  • Muffler: Temperature limiting muffler with spark arresting screen
Warranty
The warranty for the Craftsman Chain Saw 358.350810 is a full one year warranty. Within this period, if the chainsaw is maintained, lubricated, and tuned up according to the instruction manual, Sears will repair any defect in material or workmanship free of charge. However, it is important to note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for 30 days from the date of purchase. To claim warranty service, the chainsaw can be returned to the nearest Sears store or service center in the United States. It is advisable to contact the authorized service center or call Sears at 1-800-469-4663 for any questions regarding warranty rights and responsibilities.
Craftsman 358.350810 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 435
