No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.350811
Background
The Craftsman Chain Saw 358.350811 is a gasoline-powered tool primarily used for cutting wood. Manufactured by Poulan/Weedeater for Sears, this chainsaw is equipped with a 2.4 cubic inch or 40cc 2-cycle engine and an 18-inch bar. The chainsaw's operation is regulated by various controls like the ON/STOP switch, the throttle trigger, and the throttle lock-out. It is also equipped with a choke/fast idle lever for cold starting or refueling, and a primer bulb that circulates fuel to the carburetor for quicker starting.
The saw features a chain brake designed to stop the chain in case of kickback. The chain brake can activate automatically or manually if the front hand guard is pushed forward. The chain tension can be checked frequently as it is normal for a new chain to stretch during the first 15 minutes of operation. The chainsaw is also equipped with a muffler, a cylinder cover, a chain guide bar, and a bar oil fill cap. Despite the chainsaw's functionality, users are advised to conduct regular maintenance including cleaning of the air filter and spark arresting screen to ensure optimal performance.
Warranty
The warranty for the Craftsman Chain Saw 358.350811 is valid for one year from the date of purchase. If the product fails due to a defect in material or workmanship within this period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair is not possible. However, please note that the warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that may wear out in less than a year under normal use. It's important to follow the operator's manual for proper usage and maintenance to ensure warranty coverage. If you have any questions about your warranty rights and responsibilities, you can contact your nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be obtained at all Sears Service Centers by calling the same phone number.
Craftsman 358.350811 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 273
