No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3506
Background
The Craftsman Chain Saw 358.350600 is a gasoline-powered tool primarily used for cutting wood. It's manufactured by POULAN/WEEDEATER for Sears under the Craftsman brand. The chain saw is equipped with several features that help facilitate its operation. These include an ON/STOP switch for controlling the engine, a throttle trigger for managing the engine speed, and a throttle lockout that ensures the throttle trigger can only be activated intentionally.
The chain saw also features a choke/fast idle lever used for cold or refueled starting, and a primer bulb that circulates fuel to the carburetor for quicker starting. The chain brake, which stops the chain in case of kickback, can be activated either automatically or manually. This chain saw is designed for occasional use and requires regular maintenance, such as cleaning the air filter and replacing the spark plug annually, to ensure optimal performance.
Technical Specifications
  • Model Number: 358.350600
  • Product Type: Chain Saw
  • Engine: 2.6 cu.in./42cc 2-Cycle gasoline engine
  • Bar length: 18 in.
  • Maintenance schedule: Air filter - Clean every 15 tanks of fuel or 5 hours, whichever comes first. Replace filter every 50 hours or annually. Spark plug - Replace annually. Muffler and spark arresting screen - Clean every 25 hours or annually.
  • Emission system parts: Carburetor, Ignition System (Spark Plug, Ignition Module)
Warranty
The warranty for the Craftsman Chain Saw 358.350600 is valid for a period of two years from the initial date of purchase. It covers the repair or replacement of any warranted parts, which will be performed at no charge to the owner at an approved Sears servicing center. Any warranted part not scheduled for replacement as required maintenance or only scheduled for regular inspection will be warranted for 2 years. The owner will not be charged for diagnostic labor that leads to the determination of a defective warranted part if the diagnostic work is performed at an approved Sears servicing center. Sears may be liable for damages to other engine components caused by the failure of a warranted part still under warranty. The warranty does not cover failures caused by abuse, neglect, or improper maintenance. The use of add-on or modified parts can also disallow a warranty claim. To file a claim or for any questions regarding warranty rights and responsibilities, the owner should contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be obtained at all Sears service centers.
Craftsman 358.350600 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 351
