No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.350601
Background
The Craftsman Chain Saw 358.350601 is a 2-cycle gasoline-powered chainsaw with an 18-inch bar. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, the saw is primarily designed for occasional use.
The chainsaw comes with several features to enhance its functionality. The ON/STOP switch is used to stop the engine. The THROTTLE TRIGGER controls engine speed. The THROTTLE LOCKOUT must be pressed before you can squeeze the throttle trigger to prevent accidental squeezing. The CHOKE/FAST IDLE LEVER sets the choke and fast idle by pulling out fully for cold or refueled starting. The PRIMER BULB circulates fuel to the carburetor to provide quicker starting. The CHAIN BRAKE is a device designed to stop the chain if kickback occurs, which can activate automatically or manually. The saw also has a chain tension mechanism, which is normal for a new chain to stretch during the first 15 minutes of operation and should be checked frequently.
Technical Specifications
  • Product Type: Chain Saw
  • Model Number: 358.350601
  • Safety Rules: Require protective gear, keep bystanders 30 feet away, do not operate under certain conditions, clear work area and have a retreat path
  • Assembly: Fully assembled
  • Emissions Compliance: Equipped with temperature limiting muffler and spark arresting screen
  • Operation Controls: On/off switch, throttle trigger, choke/fast idle, primer bulb, chain brake
  • Maintenance: Frequent chain tension check, fuel filter rattle in empty tank, factory adjusted carburetor
  • Service and Adjustments: Chain tensioning
Warranty
The warranty for the Craftsman Chain Saw 358.350601 is for a period of two years from the initial date of purchase. The warranty covers the repair or replacement of parts, which will be performed at no charge to the owner at an approved Sears servicing center. It is important to note that failures caused by abuse, neglect, or improper maintenance are not covered by the warranty. To claim the warranty, the owner should contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty repairs should be completed in a reasonable amount of time, not exceeding 30 days.
Craftsman 358.350601 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 318
