No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35046
Background
The Craftsman Chain Saw 358.350460 is a 2-cycle gasoline-powered chain saw produced by POULAN/WEEDEATER for Sears under the Craftsman brand. The saw has a 2.2 cu.in./36cc engine and a 16-inch bar. The product is designed for occasional use and features several controls and adjustments to enhance the user's experience.
The chain saw includes an ON/STOP switch, which is used to stop the engine. Its engine speed is managed by the throttle trigger. For safety, the throttle lockout must be pressed before the throttle trigger can be squeezed. The saw also incorporates a fast idle lock that holds the throttle trigger in the starting position. The chain saw has a choke knob that activates the choke to provide additional fuel to the engine during cold starts. The primer bulb circulates fuel to the carburetor to ensure quicker starting. The chain saw is designed with a chain brake, which is a device that stops the chain if kickback occurs. The chain brake activates automatically in the event of kickback and can be manually activated by pushing the front hand guard forward. The chain saw requires regular chain tension checks, as it is normal for a new chain to stretch during the first 30 minutes of operation.
Technical Specifications
  • Model Number: 358.350460
  • Product Type: Chain Saw
  • Engine: 2.2 cu.in./36cc 2-cycle gasoline engine
  • Bar length: 16 in.
  • Chain brake: Stops chain if kickback occurs. Activates automatically or by pushing front hand guard forward. Disengage by pulling front guard back.
  • Spark arrestor: Temperature limiting muffler and spark arresting screen meets CA codes 4442 and 4443.
  • Air filter: Clean every 15 tanks of fuel or 5 hours. Replace after 50 hours or annually.
  • Spark plug: Replace annually.
  • Muffler: Inspect and clean spark arrestor screen every 25 hours or annually.
Warranty
The warranty for the Craftsman Chain Saw 358.350460 is valid for a period of two years from the initial date of purchase. The warranty covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. It is important for the owner to perform the required maintenance listed in the instruction manual and retain all receipts for maintenance on the equipment. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. To claim the warranty, the owner should present the lawn and garden equipment engine to a Sears authorized repair center as soon as a problem exists. For any questions regarding warranty rights and responsibilities, the owner can contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty service or repairs can be provided at all Sears service centers.
Craftsman 358.350460 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 36
All Time: 732
