No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.350462
Background
The Craftsman Chain Saw 358.350462 is a gasoline-powered tool designed for cutting wood. It is equipped with a 2.2 cu.in./36cc 2-cycle engine and a 16-inch bar. The chain saw features various components including an ON/STOP switch, a throttle trigger, a throttle lockout, a fast idle lock button, a choke knob, a primer bulb, and a chain brake. The ON/STOP switch is used to stop the engine, while the throttle trigger controls engine speed. The throttle lockout must be pressed before the throttle trigger can be squeezed. The fast idle lock holds the throttle trigger in the starting position. The choke knob activates the choke to provide additional fuel during cold starts. The primer bulb circulates fuel to the carburetor for quicker starting.
The chain brake is designed to stop the chain if kickback occurs and can be activated automatically or manually. The chain saw also has a feature for chain tension adjustment. It is normal for a new chain to stretch during the first 30 minutes of operation, hence frequent checking of chain tension is advised. The saw is built for occasional use and has been factory tested with the carburetor precisely adjusted. It uses a fuel mix and employs an automatic chain oiler for continuous lubrication to the chain and guide bar.
Technical Specifications
  • Model Number: 358.350462
  • Product Type: Chain Saw
  • Engine: 2.2 cu in/36cc 2-cycle gasoline engine
  • Bar Length: 16 in
Warranty
The warranty for the Craftsman Chain Saw 358.350462 is for a period of two years from the initial date of purchase. It covers the repair or replacement of parts, which will be performed at no charge to the owner at an approved Sears servicing center. The warranty period for parts that are not scheduled for replacement as required maintenance is 2 years, while parts scheduled for replacement as required maintenance are warranted for the period of time up to the first scheduled replacement point for that part. To claim the warranty, the owner should present the small off-road engine to a Sears authorized repair center as soon as a problem exists. Warranty repairs should be completed in a reasonable amount of time, not to exceed 30 days. If there are any questions regarding warranty rights and responsibilities, the nearest authorized service center or Sears can be contacted at 1-800-469-4663.
Craftsman 358.350462 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 484
