No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Documents
Models
358.35028
Background
The Craftsman Chain Saw 358.350280, manufactured by Poulan/WeedEater for Sears, is a 2.6 cubic inch, 2-cycle gasoline-powered chainsaw equipped with an 18-inch bar. The controls and adjustments on the chainsaw include an On/Stop Switch for halting the engine, a Throttle Trigger to control the engine speed, and a Throttle Lockout that requires to be pressed before the throttle trigger to prevent accidental activation. The chainsaw also has a Choke/Fast Idle Lever for adjustments during cold or refueled starts, and a Primer Bulb that circulates fuel to the carburetor for quicker starting. The chain tension on the chainsaw needs to be checked frequently, especially during the first 30 minutes of operation as it's normal for a new chain to stretch.
The chainsaw is used for cutting wood and is suitable for both commercial and residential usage. It has a chain brake system, a temperature limiting muffler, and a spark arresting screen. The chainsaw is listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI Bt 75.t-t 99t). The chainsaw's engine has been factory tested and the carburetor is precisely adjusted. The chainsaw comes fully assembled and includes a bar tool, 2-cycle engine oil, chain sharpening tool, carrying case, gloves, wedge, log carrier, and pruning saw.
Technical Specifications
  • Model Number: 358.350280
  • Product: Craftsman Chain Saw 358.350280
  • Product Type: Chain Saw
  • Engine: 2.6 cu.in./42cc 2-Cycle gas engine
  • Bar length: 18 in.
  • Safety features: Chain brake, temperature limiting muffler, spark arresting screen.
  • Approvals: UL listed, meets ANSI B175.1 safety standards.
Warranty
The warranty period for the Craftsman Chain Saw 358.350280 begins on the date of purchase and lasts for two years. The warranty covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. Diagnostic labor that leads to the determination of a defective warranted part is also covered and will not be charged to the owner. Sears may also be liable for damages to other engine components caused by the failure of a warranted part still under warranty. Failures caused by abuse, neglect, or improper maintenance are not covered by the warranty. Any use of add-on or modified parts can also void the warranty. To file a warranty claim or for any questions regarding warranty rights and responsibilities, owners should contact their nearest authorized service center or call Sears at 1-800-473-7247. Warranty services or repairs can be provided at any Sears service center.
Craftsman 358.350280 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 615
