No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.350203
Background
The Craftsman Chain Saw 358.350203 is a gasoline-powered saw designed for cutting wood. It is outfitted with a variety of controls and features to optimize its operation. The ON/STOP SWITCH is used to stop the engine, while the THROTTLE TRIGGER controls engine speed. The THROTTLE LOCK-OUT must be pressed before you can squeeze the throttle trigger, to prevent accidental operation. The CHOKE/FAST IDLE LEVER sets the choke and fast idle speed for cold or refueled starting.
The device also includes a CHAIN BRAKE designed to stop the chain if kickback occurs, which can be activated automatically or manually. The saw also features a chain tension adjustment to account for the normal stretching a new chain undergoes during the first 30 minutes of operation. The saw is equipped with a 2.8 cu.in./46cc 2-Cycle engine and a 20-inch bar. It is designed for use in a variety of settings and is suitable for both personal and commercial use.
Technical Specifications
  • Model Number: 358.350203
  • Product Type: Chain Saw
  • Engine: 2.8 cu.in./46cc 2-Cycle gas engine
  • Bar Length: 20 In.
  • Chain Brake: Yes
Warranty
The warranty for the Craftsman Chain Saw 358.350203 lasts for a period of two years from the initial date of purchase. It covers the repair or replacement of any warranted parts, which will be performed at no charge to the owner at an approved Sears servicing center. The warranty period for any warranted part not scheduled for replacement as required maintenance or only scheduled for regular inspection is 2 years. Diagnostic labor that leads to the determination of a defective warranted part is not charged to the owner if performed at an approved Sears servicing center. Sears may be liable for damages to other engine components caused by the failure of a warranted part still under warranty. The warranty does not cover failures caused by abuse, neglect, or improper maintenance, and the use of add-on or modified parts can void the warranty claim. To file a warranty claim or for any questions regarding warranty rights and responsibilities, the owner can contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be obtained at all Sears service centers by calling 1-800-469-4663.
Craftsman 358.350203 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 37
All Time: 379
