No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35008
Background
The Craftsman Chain Saw Model 358.350080 is a gasoline-powered saw with a 2.4 cubic inch/40cc 2-cycle engine. The saw features an 18-inch bar for cutting various types of wood. It is equipped with a variety of controls and adjustments including an ON/STOP switch, a throttle trigger, a throttle lockout, and a fast idle lock. The ON/STOP switch is used to stop the engine and the throttle trigger controls the engine speed. The throttle lockout must be pressed before the throttle trigger can be squeezed. The fast idle lock holds the throttle trigger in the starting position.
The chain saw also includes a choke knob and a primer bulb. The choke knob activates the choke to provide additional fuel to the engine during cold starting, while the primer bulb circulates fuel to the carburetor to provide quicker starting. The chain tension can be adjusted as required, considering that a new chain usually stretches during the first 30 minutes of operation. The saw also includes a chain catcher, guide bar, and front handle. The chain catcher prevents the chain from snapping back in case it breaks or jumps off the guide bar. The front handle provides the operator with control while using the saw.
Technical Specifications
  • Model Number: 358.350080
  • Product Type: Gasoline Chain Saw
  • Engine: 2.4 cu. in./40cc 2-Cycle
  • Bar Length: 18 inches
Warranty
The Craftsman Chain Saw 358.350080 comes with a full one-year warranty provided by Sears. Within this period, starting from the date of purchase, Sears will repair any defect in material or workmanship free of charge, as long as the chainsaw is maintained, lubricated, and tuned-up according to the owner's manual. However, the warranty does not cover expendable parts such as the bar, chain, spark plug, and air filter, which are expected to wear out during normal use. It is important to note that if the chainsaw is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty service, customers need to return the chainsaw to the nearest Sears Service Center in the United States. It is also important to understand that this warranty provides specific legal rights, which may vary from state to state, and customers may have additional rights beyond what is mentioned.
Craftsman 358.350080 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 427
