No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3418
Background
The Craftsman Chain Saw 358.34180 is a chainsaw manufactured by Poulan/WeedEater for Sears under the Craftsman brand. It operates with a voltage of 120 Volt AC 50_60 Hz. The chainsaw is available in two versions, one with a 10.5 amp motor and a 14-inch guide bar, and a second version with a 12 amp motor and a 16-inch guide bar. The chainsaw utilizes a low profile 3/8" pitch chain and features a manual oiler for lubrication. It also uses a gear drive system for power transmission.
The Craftsman Chain Saw 358.34180 is mainly used for cutting wood. This chainsaw has various controls and adjustments that help to improve its performance. These include an on/stop switch that controls the engine, a throttle trigger that regulates engine speed, a guide bar that carries the chain, and cutters that are designed to cut wood. The chainsaw also features an adjusting screw that is used to tension the chain around the guide bar, and bar clamp nuts that hold the guide bar in place after adjustments have been made.
Technical Specifications
  • Model Number: 358.34180
  • Product: Craftsman Chain Saw 358.34180
  • Product Type: Chain Saw
  • Voltage: 120 Volt AC, 50/60 Hz
  • Amps: 12 Amps
  • Guide Bar Length: 16"
  • Chain Type: Low Profile 3/8" Pitch
  • Oiler: Manual
  • Drive System: Gear Drive
Craftsman 358.34180 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 383
