2 Diagrams
Documents
Models
316.35084
Background
The Craftsman Chain Saw 316.350840 is a versatile tool designed for cutting tasks. It is manufactured by Ryobi America Corp for Sears under the Craftsman Brand. The chainsaw features an air-cooled, 2-cycle engine with a displacement of 55 cc (3.36 cu in.). It operates at a speed of 7,200+ RPM, with an idle speed RPM of 3,400. The chainsaw uses an electronic ignition type, and a slide switch for the ignition switch. Its lubrication comes from a fuel/oil mixture with a ratio of 40:1. The chainsaw's fuel tank has a capacity of 16.8 oz. (496.8 ml). The chainsaw weighs approximately 17.6 lbs. (8 kg) without fuel. It can cut diameters of up to 36 inches (91.4 cm).
The chainsaw is equipped with features that enhance its performance and usability. The diaphragm, all-position carburetor ensures a consistent fuel supply. The auto rewind starter ensures a reliable start-up. It has a baffled muffler with a guard to control exhaust gases and noise. The throttle control is a finger-tip trigger, ensuring user-friendly operation. It also has a manual spring return throttle that ensures the engine returns to idle when the throttle is released. For cutting efficiency, the chainsaw has a 36-inch (91.4 cm) cutting diameter. To ensure durability, the chainsaw features a robust design that can withstand rigorous use.
Technical Specifications
  • Model Number: 316.350840
  • Product Type: Chain Saw
  • Engine Type: Air-Cooled, 2-Cycle
  • Displacement: 55 cc (3.36 cu in.)
  • Idle Speed RPM: 3,400 rpm
  • Operating RPM: 7,200+ rpm
  • Ignition Type: Electronic
  • Ignition Switch: Slide Switch
  • Spark Plug Gap: 0.025 in. (0.635 mm)
  • Lubrication: Fuel/Oil Mixture
  • Fuel/Oil Ratio: 40:1
  • Carburetor: Diaphragm, All-Position
  • Starter: Auto Rewind
  • Muffler: Baffled with Guard
  • Throttle: Manual Spring Return
  • Fuel Tank Capacity: 16.8 oz. (496.8 ml)
  • Throttle Control: Finger-Tip Trigger
  • Approximate Unit Weight (No fuel): 17.6 lbs. (8 kg)
  • Cutting Diameter: 36 in. (91.4 cm)
Warranty
The Craftsman Chain Saw 316.350840 comes with a one-year limited warranty. This warranty covers any defects in material or workmanship and entitles the owner to free repair services, as long as the chainsaw is used and maintained according to the operator's manual. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, which are considered expendable parts that may wear out within two years of normal use. If the chainsaw is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty, you can return the chainsaw to the nearest Sears store or Sears Parts & Service Center in the United States. It is important to note that this warranty provides specific legal rights, and you may also have additional rights that vary from state to state. For any further inquiries about your warranty rights and responsibilities, you can contact Sears at 1-800-4-MY-HOMEĀ®.
Craftsman 316.350840 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 34
All Time: 901
