1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
316.35022
Background
The Craftsman Chain Saw 316.350220 is a product of Ryobi America Corp for Sears under the Craftsman Brand. This air-cooled, 2-cycle chain saw utilizes a displacement of 55 cc (3.36 cu in.) and operates at an idle speed of 3,400 RPM, and can reach over 7,200 RPM. The chain saw features an electronic ignition, slide switch for ignition, and a fuel/oil mixture for lubrication. It also uses a diaphragm, all-position carburetor, and a manual spring return throttle. The fuel tank has a capacity of 16.8 oz. (496.8 ml), and the unit weighs approximately 17.6 lbs. (8 kg) without fuel.
The Craftsman Chain Saw 316.350220 is suitable for various cutting tasks and is designed for longevity and reliable performance. It uses an electronic-MAX fire ignition system and an Incred-Pull Starting Auto Rewind starter mechanism for ease of use. The throttle control is a finger-tip trigger type, allowing for precise control during operation. The chain saw also includes a muffler with a guard. For efficient operation, it uses a fuel/oil ratio of 40:1 and has an all-position diaphragm carburetor. Maintenance and repair of the chain saw can be done using its specified components and parts as listed in the manual.
Technical Specifications
  • Model Number: 316.350220
  • Product Type: Chain Saw
  • Engine Type: Air-Cooled, 2-Cycle
  • Displacement: 55 cc (3.36 cu in.)
  • Idle Speed RPM: 3,400 rpm
  • Operating RPM: 7,200+ rpm
  • Ignition Type: Electronic
  • Ignition Switch: Slide Switch
  • Spark Plug Gap: 0.025 in. (0.635 mm)
  • Lubrication: Fuel/Oil Mixture
  • Fuel/Oil Ratio: 40:1
  • Carburetor: Diaphragm, All-Position
  • Starter: Auto Rewind
  • Muffler: Baffled with Guard
  • Throttle: Manual Spring Return
  • Fuel Tank Capacity: 16.8 oz. (496.8 ml)
  • Throttle Control: Finger-Tip Trigger
  • Approximate Unit Weight (No fuel): 17.6 lbs. (8 kg)
Warranty
The warranty for the Craftsman Chain Saw 316.350220 is a one-year full warranty. If the chain saw fails due to a defect in material or workmanship within one year from the date of purchase and it has been used and maintained according to the operator's manual, it can be returned to any Sears store, Sears Parts & Repair Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, which are considered expendable parts that can wear out in less than one year due to normal use. It is important to mention that the warranty only applies for 30 days from the date of purchase if the chain saw is used for commercial or rental purposes. To claim the warranty, simply return the chain saw to the aforementioned locations for repair or replacement.
Craftsman 316.350220 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 644
