Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.797931
Background
The Craftsman Blower 358.797931 is a versatile outdoor tool manufactured by Poulan/Weedeater for Sears. The product, which operates on a 2-cycle gasoline-powered engine, functions as a blower, vacuum, and mulcher, offering multiple uses for garden clean-up and maintenance tasks.
The blower features several control mechanisms designed to enhance its performance and user experience. It is equipped with an ON/STOP switch used to halt the engine, with the switch designed to stay in the ON position when not in use. To aid in the starting of a cold engine, the blower has a Cold Start feature which supplies fuel to the carburetor during startup. Once the engine has started, the Cold Start lever can be moved to the Run position. The unit also includes a Primer Button that removes air from the fuel lines and fills them with fuel, allowing the engine to start with fewer pulls on the starter rope. For controlling engine speed, the blower uses a Speed Control mechanism. The product operates on unleaded gasoline mixed with a good quality 2-cycle air-cooled engine oil at a ratio of 40:1.
Technical Specifications
  • Product Type: Blower
  • Model Number: 358.797931
  • Engine: 1.4 cu. in./24cc 2-Cycle GASOLINE POWERED
Warranty
The warranty for the Craftsman Blower 358.797931 is a full two-year warranty. This warranty covers any defects in material or workmanship of the blower, excluding blower tubes, spark plug, and air cleaner, which are considered expendable parts that may wear out during normal use. The warranty is valid as long as the blower is maintained, lubricated, and tuned up according to the instructions in the operator's manual. If the blower is used for commercial purposes, the warranty applies for 90 days from the date of purchase, and if used for rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, customers can return the blower to the nearest Sears service center in the United States. It is important to note that failure to follow all safety rules and precautions may result in serious injury.
Craftsman 358.797931 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 40
All Time: 669
