Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79792
Background
The Craftsman Blower 358.797920 is a gas-powered blow tool designed by POULAN/WEEDEATER for Sears. This 2-cycle engine blower is equipped with a direct drive and a vibration-dampened handle. It is lightweight, weighing only 12 lbs, and designed for convenient upright storage. The top handle allows for one-handed operation. The product is engineered for versatility, capable of blowing or vacuuming debris depending on the user’s needs.
The Craftsman Blower has a high performance and is designed for various jobs. Its durability and reliability are supported by its capability to operate between 7000 to 7600 RPM while idle operates between 3800 to 4600 RPM. The device also provides an option for a gutter attachment kit for additional functionality. The product is geared towards long-term use, highlighting the importance of proper maintenance for optimal performance.
Technical Specifications
  • Model Number: 358.797920
  • Product Type: Blower
  • Engine: 2-cycle air cooled, 22cc or 32cc displacement
  • Engine RPM (Operating): 7000-7600 rpm
  • Engine RPM (Idle): 3800-4600 rpm
  • Starter: Auto rewind
  • Ignition: Positive rocker
  • Spark Plug: Torch F6TC (for 22cc models), Torch F7TC (for 32cc models)
  • Fuel Tank Capacity: 18.6 fl oz
  • Lubrication: 3.2 fl oz 2-cycle engine oil
  • Weight: 12 lbs
  • Blower Tubes: Direct drive
  • Handle: Vibration dampened
  • Storage: Upright
  • Accessory: Gutter cleaning attachment kit
Warranty
The warranty for the Craftsman Blower 358.797920 is valid for two years from the date of purchase. During this period, the warranty covers maintenance, lubrication, and normal use of the blower. However, the warranty does not cover the blower tube, spark plug, and air cleaner, as these are considered expendable parts that may wear out over time. If the blower is used for commercial or rental purposes, the warranty applies for only 90 days. To claim the warranty, customers can avail warranty service by returning the unit to the nearest Sears service center or department. It is important to note that this warranty is applicable only when the product is used within the United States.
Craftsman 358.797920 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 65
All Time: 858
