Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.797341
Background
The Craftsman Blower 358.797341 is a versatile tool designed for various yard clean-up tasks. This blower is powered by a 25cc two-cycle gasoline engine, which is capable of releasing air at a speed of 205 miles per hour and a volume of 410 cubic feet per minute. The blower can be used to sweep debris or grass clippings from driveways, sidewalks, patios, or to blow grass clippings, straw, or leaves into piles around joints or between bricks.
Furthermore, this Craftsman Blower also functions as a vacuum, ideal for picking up dry material such as leaves, grass, small twigs, and bits of paper. For best results during vacuum use, it is suggested to operate the unit at high speed and move slowly back and forth over the material being vacuumed. The unit is designed for durability and repairability, with maintenance tasks such as cleaning the air filter and replacing the spark plug or fuel filter being a part of its regular upkeep for optimal performance and longevity.
Technical Specifications
  • Model Number: 358.797341
  • Product: Craftsman Blower 358.797341
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Size: 25cc/1.5 cu.in.
  • Air Speed: 205 MPH
  • Air Volume: 410 CFM
  • Power Source: Gasoline
Warranty
The Craftsman Blower 358.797341 comes with a warranty period of two years from the initial date of purchase. The warranty covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. It is important for the owner to perform the required maintenance listed in the instruction manual to ensure warranty coverage. Sears recommends retaining all receipts covering maintenance on the blower but cannot deny warranty solely for the lack of receipts. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. To claim the warranty, the owner should contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty service is available by returning the blower to the nearest Sears store or service center in the United States. It is important to note that all failures caused by abuse, neglect, or improper maintenance are not covered by the warranty. The use of add-on or modified parts can also void the warranty.
Craftsman 358.797341 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 477
