Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79729
Background
The Craftsman Blower 358.797290 is a gas-powered tool designed for outdoor use. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, it features a 1.4 cubic inch/24cc 2-cycle engine, which can generate an air speed of up to 205 miles per hour and an air volume of up to 410 cubic feet per minute. This blower is equipped with an impeller assembly, a choke lever, and a throttle linkage. It also includes a carburetor adaptor and a mulch blade/key.
The Craftsman Blower is used for blowing leaves, debris, and other lightweight materials in outdoor spaces such as gardens, patios, and driveways. It can also be used for mulching, which involves reducing leaves and other organic materials into smaller pieces for use as a soil additive. The engine of the blower is designed to meet stringent anti-smog standards, contributing to environmental conservation. The blower's parts, including the carburetor and the ignition system, are designed to be repairable, ensuring the longevity of the product.
Technical Specifications
  • Model Number: 358.797290
  • Product: Craftsman Blower 358.797290
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Size: 1.4 cu.in./24cc
  • Air Speed: 205 MPH
  • Air Volume: 410 CFM
  • Power Source: Gasoline
  • Mulching Ratio: Up to 16:1
  • Primer Button: Yes
  • Choke: Yes
  • On/Stop Switch: Yes
Warranty
The Craftsman Blower 358.797290 comes with a warranty period of two years from the date of purchase. The warranty covers the repair or replacement of parts. Any warranted part that is scheduled for replacement or is found to be defective will be repaired or replaced by SEARS, ROEBUCK AND CO. at no charge to the owner. To claim the warranty, owners should contact their nearest authorized service center or call SEARS, ROEBUCK AND CO. at 1-800-235-5878. It is important to note that failures caused by abuse, neglect, or improper maintenance are not covered by the warranty. Additionally, the warranty does not cover add-on or modified parts.
Craftsman 358.797290 Owners Manual
Craftsman 358.797290 24cc 2-Cycle Gasoline Blower/Vac Operator's Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 43
All Time: 740
