Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.797251
Background
The Craftsman Blower 358.797251 is a gasoline-powered tool manufactured by Poulan/WeedEater for Sears under the Craftsman brand. This blower is designed to efficiently clear out debris from outdoor spaces such as gardens and patios. The blower's key features include mulching blades, which are used to reduce debris at a ratio of up to 16:1, making it useful for maintaining clean outdoor areas. The unit also comes with a throttle lock that is used to hold the throttle in the run and starting positions, a throttle trigger that controls engine speed, and a choke that helps supply fuel to the engine to aid in cold starting.
When it comes to starting the engine, the Craftsman Blower 358.797251 has a primer bulb that removes air from the carburetor and fuel lines, filling them with fuel, which allows the engine to start with fewer pulls on the starter rope. The ON/STOP switch is used to stop the engine. To ensure longevity and durability, it is recommended to regularly check for loose fasteners and parts, check for damaged or worn parts, clean the unit and labels, clean the air filter and replace the spark plug as part of routine maintenance.
Technical Specifications
  • Model Number: 358.797251
  • Product: Craftsman Blower 358.797251
  • Product Type: Blower
Warranty
The Craftsman Blower 358.797251 comes with a one-year warranty from the date of purchase. During this warranty period, Sears will repair any defects in material or workmanship free of charge, provided that the blower is maintained, lubricated, and tuned up according to the instructions in the operator's manual. However, please note that the warranty excludes blower tubes, spark plug, and air cleaner, which are considered expendable parts that may become worn during normal use. If the blower is used for commercial purposes, the warranty applies for 90 days, and if used for rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, you can return the blower to the nearest Sears service center in the United States. It is important to read and understand all safety rules and precautions mentioned in the manual before operating the blower to avoid any potential injuries.
Craftsman 358.797251 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 745
