Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79712
Background
The Craftsman Blower 358.797120 is a gasoline-powered tool designed to conveniently remove debris or grass clippings from various outdoor surfaces. The blower is equipped with a 25cc, 2-cycle engine that can generate an airflow speed of up to 185 miles per hour and a volume of 385 cubic feet per minute.
The blower has a number of features that contribute to its functionality and user-friendliness. These include a throttle lever, which is used to select the desired engine speed and to stop the engine, and a primer button, which removes air from the carburetor and fuel lines, filling them with fuel for easier starting. The blower also has a choke lever that helps supply fuel to the engine for easier cold starting. Apart from being used to sweep debris or grass clippings from driveways, sidewalks, and patios, the blower can also be used to blow grass clippings, straw, or leaves into piles, around joints, or between bricks. The blower's performance can be further optimized by dampening surfaces in dusty conditions or using a mister attachment when water is available.
Technical Specifications
  • Model Number: 358.797120
  • Product: Craftsman Blower 358.797120
  • Product Type: Blower
  • Engine: 2-Cycle, 25cc/1.5 cu.in.
  • Air Speed: 185 MPH
  • Air Volume: 385 CFM
  • Power Source: Gasoline
Warranty
The warranty for the Craftsman Blower 358.797120 lasts for two years from the initial date of purchase. It covers the repair or replacement of any warranted parts, which will be performed at no charge to the owner at an approved Sears servicing center. Any warranted part that is not scheduled for replacement as required maintenance or is scheduled only for regular inspection will be warranted for 2 years. The owner will not be charged for diagnostic labor that leads to the determination of a defective warranted part if the diagnostic work is performed at an approved Sears servicing center. Sears may be liable for damages to other engine components caused by the failure of a warranted part still under warranty. All failures caused by abuse, neglect, or improper maintenance are not covered by the warranty. To file a warranty claim, the owner should contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be provided at all Sears service centers.
Craftsman 358.797120 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 483
