3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.794963
Background
The Craftsman Blower 358.794963 is a gasoline-powered blower/vacuum, designed and manufactured by Poulan/Weedeater for Sears under the Craftsman brand. The product features a 25cc/1.5 cu.in. 2-Cycle engine, capable of producing an air speed of 205 MPH and an air volume of 410 CFM, to help with both blowing and vacuuming tasks. The machine includes an innovative mulching blade, which automatically reduces debris at a ratio of up to 16:1 when using the vacuum attachment.
The blower is equipped with controls such as a throttle lever, a primer button, and a choke lever to manage the engine speed, start the engine with fewer pulls on the starter rope, and aid in cold starting, respectively. The product is designed to be operated at reasonable hours, limiting noise and disturbance. It is built to last and is seen as a reliable product for both domestic and commercial use. The design of the blower promotes repairability and longevity, showcasing the product's durability.
Technical Specifications
  • Model Number: 358.794963
  • Product: Craftsman Blower 358.794963
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Displacement: 25cc/1.5 cu.in.
  • Air Speed: 205 MPH
  • Air Volume: 410 CFM
  • Power Source: Gasoline
  • Mulching Ratio: Up to 16:1
  • Throttle Positions: Full speed, idle speed, stop position
  • Additional Attachments: Vacuum attachment, mulching blades
Warranty
The Craftsman Blower 358.794963 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may arise within two years from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair proves to be impossible. However, please note that the warranty does not cover the spark plug and air cleaner, which are considered expendable parts that can wear out from normal use in less than two years. It is important to mention that this warranty only applies for 30 days from the date of purchase if the product is used for commercial or rental purposes. To claim the warranty, you can contact any Sears Service Center or call 1-800-469-4663. Additionally, the owner is responsible for performing all required maintenance as defined in the operator's manual.
Craftsman 358.794963 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 430
