Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79477
Background
The Craftsman Blower 358.794770 is a versatile outdoor tool designed for both blowing and vacuuming tasks. Manufactured by Poulan/Weedeater for Sears, it is equipped with a 25cc 2-cycle engine, capable of producing an air speed of 215 MPH and an air volume of 470 cubic feet per minute (CFM). This blower is ideal for sweeping debris or grass clippings from driveways, sidewalks, and patios, as well as blowing grass clippings, straw, or leaves into piles.
In addition to its blowing capabilities, the Craftsman Blower 358.794770 can also function as a vacuum, picking up dry materials such as leaves, grass, small twigs, and bits of paper. It features mulching blades that automatically reduce debris at a ratio of up to 16:1 when using the vacuum attachment. The blower is equipped with a throttle position lever for setting engine speed during blower use, a stop switch for stopping the engine, and a primer bulb for facilitating engine start. It is designed for durability, reliability, and repairability, with a focus on longevity.
Technical Specifications
  • Product Type: Blower
  • Model Number: 358.794770
  • Engine Type: 2-Cycle
  • Engine Size: 25cc/1.5 cu.in.
  • Blower Speed: 215 MPH
  • Air Volume: 470 CFM
  • Fuel Type: Gasoline
  • Spark Plug Type: Champion RCJ-CY
  • Spark Plug Gap: 0.025 inch
  • Air Filter Type: Washable
  • Muffler: Yes, with Spark Arresting Screen
Warranty
The Craftsman Blower model 358.794770 comes with a two-year full warranty. This warranty applies if the product fails due to a defect in material or workmanship within two years from the date of purchase. To claim the warranty, the product should be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair. If repair is not possible, the product may be replaced.
The warranty does not cover the spark plug and air cleaner, as these are considered expendable parts that can wear out from normal use in less than two years. If the product is used for commercial or rental purposes, the warranty applies for only 30 days from the date of purchase.
Warranty services or repairs can be obtained at all Sears Service Centers or by calling 1-800-469-4663. Any Sears approved replacement part used in the performance of any warranty maintenance or repair on emission-related parts will be provided without charge to the owner if the part is under warranty.
The owner is responsible for the performance of all required maintenance as defined in the instruction manual.
Craftsman 358.794770 Owners Manual
Craftsman 358.794770 Gasoline Powered Blower/Vac Operator's Manual (EN, ES)
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 37
All Time: 701
