Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.794771
Background
The Craftsman Blower 358.794771 is a gasoline-powered device, designed to help with the removal of debris like leaves, grass, and small twigs from outdoor spaces. It is manufactured by Poulan/Weedeater for Sears under the Craftsman brand, and designed to generate a wind force of 215 MPH/470 CFM. The blower is equipped with a 25cc/1.5 cu.in. 2-Cycle engine, which ensures its reliable and long-lasting performance.
This Blower is also equipped with a vacuum attachment designed to pick up dry material. However, it should not be used to vacuum hard materials such as stones, gravel, metal or broken glass to avoid damage to the impeller. It also features an air filter which is crucial to maintain the performance of the engine, reduce fuel consumption and decrease harmful emissions. The air filter needs to be cleaned after every 5 hours of operation to ensure the blower's efficiency. Moreover, it has a spark plug that needs to be replaced annually to ensure easy start and better operation of the engine. The unit also contains a muffler which is integral to its operation and needs to be checked for carbon deposits buildup.
Technical Specifications
  • Model Number: 358.794771
  • Product: Craftsman Blower 358.794771
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Displacement: 25cc/1.5 cu.in.
  • Air Velocity: 215 MPH
  • Air Volume: 470 CFM
  • Fuel Type: Gasoline-powered
Warranty
The Craftsman Blower 358.794771 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may occur within two years from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair is not possible. However, please note that the warranty does not cover the spark plug and air cleaner, as they are considered expendable parts that can wear out within two years of normal use. It is also important to mention that if the blower is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty, customers can contact Sears Service Centers at 1-800-469-4663.
Craftsman 358.794771 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 370
