Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.794765
Background
The Craftsman Blower 358.794765 is a gasoline-powered product designed for clearing various types of debris. It is equipped with a range of features that enhance its performance and utility. Among these features are mulching blades, which reduce debris at a ratio of up to 16:1 when used with a vacuum attachment. This blower also comes with a throttle position lever and a throttle trigger, allowing users to select the desired engine speed during operation.
Additional features of the Craftsman Blower 358.794765 include a primer bulb and a start lever. The primer bulb is designed to remove air from the carburetor and fuel lines, filling them with fuel for easier engine start-up. The start lever, on the other hand, supplies fuel to the engine to aid in the starting process. This blower is notable for its durability and reliability, as well as its repairability, making it a long-lasting tool for various outdoor cleaning tasks.
Technical Specifications
  • Model Number: 358.794765
  • Product: Craftsman Blower 358.794765
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Size: 25cc/1.5 cu.in.
  • Maximum Air Speed: 210 MPH
  • Maximum Air Volume: 450 CFM
  • Fuel Type: Gasoline
  • Fuel Ratio: 40:1 (gasoline to oil)
  • Fuel Capacity: Not specified
  • Mulching Ratio: Up to 16:1
Warranty
The Craftsman Blower 358.794765 comes with a full warranty that lasts for two years from the date of purchase. If the product fails due to a defect in material or workmanship within this timeframe, you can return it to any Sears store, Parts & Repair Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, please note that the warranty only covers defects in material and workmanship and is valid for 90 days if the product is used for commercial or rental purposes. Certain items that can wear out from normal use, such as the vacuum bag, filter, or spark plug, are not covered by the warranty. Additionally, Sears will not cover repairs resulting from accidents, failure to operate or maintain the product according to the instructions, or improper fuel mixture or contaminated fuel. To claim the warranty, simply bring the product to an authorized service center or contact Sears directly.
Craftsman 358.794765 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 576
