3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.794741
Background
The Craftsman Blower 358.794741 is a gas-powered blower manufactured by Poulan/Weedeater for Sears. This blower features a 25cc/1.5 cu.in. 2-cycle engine, capable of producing air speeds of up to 200 miles per hour and air volume of up to 430 cubic feet per minute. In addition to the blower function, the device can also be used as a vacuum, designed to pick up dry materials such as leaves, grass, and small twigs.
The blower is primarily used for gardening applications, including clearing debris from areas such as gutters, screens, patios, and gardens. It is also capable of operating in dusty conditions and can be used effectively to conserve water in many lawn and garden applications. The blower requires a mixture of unleaded gasoline and a good quality synthetic 2-cycle air-cooled engine oil to operate, with a recommended mixing ratio of 40:1. This fuel mixture allows the blower to function efficiently and reliably over extended periods of use.
Technical Specifications
  • Model Number: 358.794741
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Size: 25cc/1.5 cu.in.
  • Maximum Air Speed: 200 MPH
  • Maximum Air Volume: 430 CFM
  • Fuel Type: Gasoline
Warranty
The Craftsman Blower 358.794741 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may occur within two years of the purchase date. If the product fails due to such defects, the customer can return it to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, depending on the severity of the issue. It's important to note that the warranty does not cover expendable parts like spark plugs and air cleaners, which can wear out from normal use in less than two years. Additionally, if the blower is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty, customers can contact any Sears Service Center or call 1-800-469-4663.
Craftsman 358.794741 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 39
All Time: 470
