Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79473
Background
The Craftsman Blower 358.794730, manufactured by Poulan/WeedEater for Sears, is a gas-powered unit designed for cleaning and maintenance tasks. Its key features include a throttle trigger to select the desired engine speed, a primer bulb to remove air from the carburetor and fuel lines, and a choke lever to aid in cold starting. The blower also comes equipped with an upper and lower vacuum tube, an elbow tube, a high-speed nozzle, and a fuel mix fill cap.
The Craftsman Blower 358.794730 is a versatile tool that can be used for a variety of outdoor cleaning tasks. It can be used to vacuum or blow debris, making it an ideal tool for maintaining lawns, gardens, patios, porches, gutters, and screens. It is also useful for loosening debris before blowing and conserving water by serving as an alternative to hoses for many lawn and garden applications. The blower's design allows for a reasonable degree of user control, with a stop switch to halt the engine and a throttle trigger to adjust engine speed according to the task at hand.
Technical Specifications
  • Model Number: 358.794730
  • Product: Craftsman Blower 358.794730
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Size: 25cc/1.5 cu.in.
  • Air Speed: 200 MPH
  • Air Volume: 430 CFM
  • Power Source: Gasoline
Warranty
The Craftsman Blower 358.794730 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may arise within two years from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair. In cases where repair is not possible, the product will be replaced. It is important to note that the warranty excludes the spark plug and air cleaner, which are considered expendable parts and may wear out in less than two years. Additionally, if the blower is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty, customers can contact any Sears Service Center or call 1-800-469-4663.
Craftsman 358.794730 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 519
