2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.79497, 316.794970
Background
The Craftsman Blower 316.794970, manufactured by Ryobi America Corp for Sears, is a versatile piece of equipment designed for both blowing and vacuuming tasks. It operates on a 31.5cc air-cooled, 2-cycle engine that can reach an idle speed RPM of 3,200-4,400 and a blower operating RPM of 7,200+. The blower can achieve a velocity of up to 205 mph and an air output of up to 425 cfm. The product also features a fuel/oil mixture lubrication system with a 40:1 fuel/oil ratio, and a diaphragm, all-position carburetor.
The Craftsman Blower 316.794970 also functions as a vacuum, with a mulching ratio of up to 10:1 and a vacuum bag capacity of 1.5 bushels. It is equipped with a single quick-snap shoulder strap for comfortable use. The unit weighs approximately 11.3 lb without fuel and with the blower tube attached. This blower/vacuum is suitable for cleaning yards, garages, driveways, porches, patios, around walls, fences, and more. When used as a vacuum, it can efficiently pick up leaves and other light debris.
Technical Specifications
- Engine Type: Air-Cooled, 2-Cycle
- Displacement: 31.5cc (1.95cu.in)
- Idle Speed RPM: 3,200- 4,400rpm
- Vacuum Operating RPM: 6,800+rpm
- Blower Operating RPM: 7,200+rpm
- Ignition Type: Electronic
- On/Off Stop Control: Rocker Switch
- Spark Plug Gap: 0.020 inch (0.5 mm)
- Lubrication: Fuel/Oil Mixture
- Fuel/Oil Ratio: 40:1
- Carburetor: Diaphragm, All-Position
- Starter: Auto Rewind
- Muffler: Baffled with Guard
- Fuel Tank Capacity: 13 ounces (384 ml)
- Throttle Control: Finger-Tip Lever
- Blower Velocity: up to 205 mph (330 kmh)
- Blower Air Output: up to 425 cfm (12.1 cmm)
- Mulching Ratio: up to 10:1
- Vacuum Bag Capacity: 1.5 bushels (52.8 Liters)
- Shoulder Strap: Single Quick-Snap
- Approximate Unit Weight (no fuel, with blower tube): 11.3 lb. (5.2 kg)
- Hearing protection: Gutter Clean Out Adapter
Warranty
The Craftsman Blower model 316.794970 comes with a two-year limited warranty from the date of purchase. This warranty covers any defects in material or workmanship, provided the blower is used and maintained according to the operator's manual. Sears will repair these defects free of charge. However, the warranty does not cover the spark plug, air filter, and vacuum bag as these are expendable parts that can wear out from normal use in less than two years.
If the blower is used for commercial or rental purposes, the warranty applies for only 30 days from the date of purchase. To claim the warranty, you need to return the blower to the nearest Sears store or Sears Parts & Repair Center in the United States.
The product also has a California/EPA Emission Control Warranty for two years. This covers parts such as the carburetor or fuel-injection system, the ignition system, and catalytic converter, as well as hoses, belts, connectors, and other emission-related assemblies. If any emission-related part on your engine is defective, the part will be repaired or replaced by Sears at no cost to you, including diagnosis, parts, and labor.
To claim this warranty, you should present your small off-road engine to a Sears authorized service center as soon as a problem exists. The warranty repairs should be completed in a reasonable amount of time, not to exceed 30 days. For the nearest location, please contact Sears at 1-800-4-MY-HOMEĀ®.
Please note, warranty coverage may be denied if your small off-road engine or a part has failed due to abuse, neglect, improper maintenance, or unapproved modifications. Also, the use of add-on or modified parts can be grounds for disallowing a warranty claim.
Craftsman 316.794970 Owners Manual
Craftsman 316.794970 2-Cycle Mulching Blower/Vacuum Operator's Manual
Craftsman 316.794970 2-Cycle Mulching Blower/Vacuum Operator's Manual (EN, ES)
