Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
316.7948
Background
The Craftsman Blower 316.794800 is a handheld outdoor tool powered by a 4-cycle, air-cooled engine with a displacement of 1.95 inches (32cc). It operates within a range of 5,500 to 6,500 RPM and possess an idle speed RPM of 3,800 to 4,400. The blower uses a diaphragm, all-position carburetor for fuel management and comes equipped with an electronic ignition system for reliable startups. The blower's lubrication is facilitated by SAE 30 oil, and its crankcase has an oil capacity of 3.04 oz (90 ml).
The Craftsman Blower 316.794800 runs on unleaded fuel, with a fuel tank capacity of 26 oz (769 ml). It features manual spring return throttle for controlling speed and power, and a baffled muffler with a guard for noise reduction. The ignition switch is a rocker switch, an easily accessible and simple mechanism. This blower is mainly used for tasks such as clearing leaves, debris, and grass cuttings from gardens, yards, or other outdoor areas. With its robust engine and functional design, the Craftsman Blower 316.794800 is a durable and reliable tool for various outdoor cleanup tasks.
Technical Specifications
  • Model Number: 316.794800
  • Product: Craftsman Blower 316.794800
  • Product Type: Blower
  • Engine Type: Air-Cooled, 4-Cycle
  • Displacement: 1.95in.s(32cc)
  • Operating RPM: 5,500-6,500 rpm
  • Idle Speed RPM: 3,800-4,400 rpm
  • Ignition Type: Electronic
  • Ignition Switch: Rocker Switch
  • Valve Clearance: 0.003-0.006 in.(0.076-0.152 mm)
  • Spark Plug Gap: 0.025 inch(0.635mm)
  • Lubrication: SAE30 Oil
  • Crankcase Oil Capacity: 3.04oz(90ml)
  • Fuel: Unleaded
  • Carburetor: Diaphragm, All-Position
  • Starter: Spring Assist Starting TM Auto Rewind
  • Muffler: Baffled with Guard
  • Throttle: Manual Spring Return
  • Fuel Tank Capacity: 26 oz (769 ml)
Warranty
The warranty for the Craftsman Blower 316.794800 is for two years. The warranty covers the evaporative emission control system, which includes parts such as carburetors, fuel tanks, fuel lines, fuel caps, valves, canisters, filters, vapor hoses, clamps, connectors, and other associated components. If any of these parts are defective, they will be repaired or replaced by Sears. As the owner, you are responsible for performing the required maintenance listed in the owner's manual. It is recommended that you retain all receipts covering maintenance, although the lack of receipts will not solely deny warranty coverage. If you believe there is a problem with your blower, you should present it to a Sears distribution center or service center as soon as possible. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. If you have any questions about your warranty coverage, you can contact Sears at 1-800-4-MY-HOMEĀ®.
Craftsman 316.794800 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 389
