Up to 20% off select tools
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
316.7916
Background
The Craftsman Blower model number 316.791600 is a handheld device designed to remove debris such as leaves and grass from outdoor spaces. Manufactured by Ryobi America Corp for Sears under the Craftsman brand, this blower operates on a 2-cycle internal combustion engine. Notable for its durability and reliability, the blower is equipped with a spark arrestor, a feature designed to prevent the emission of flammable debris, reducing the risk of fire. This makes it suitable for use in forested or grass-covered areas, particularly in states such as California, Maine, Oregon, and Washington where the use of a spark arrestor is a legal requirement for certain engines.
The Craftsman Blower 316.791600 is intended for occasional, household use. It is designed to be operated in well-ventilated outdoor areas, and its handheld design allows for ease of use and maneuverability. The blower is also equipped with a throttle control that automatically returns to the idle position, offering the user greater control over the device's operation. Despite its compact size, the blower is capable of effectively clearing a wide area of debris, making it a practical tool for maintaining clean and tidy outdoor spaces.
Technical Specifications
  • Product Type: Blower
  • Engine Type: Air-Cooled, 2-Cycle
  • Displacement: 25 cc (1.52 cu. in.)
  • Spark Plug Gap: 0.025 in. (0.635 mm)
  • Spark Plug: Champion RDJ7J or equivalent plug
  • Lubrication: Fuel/Oil Mixture
  • Fuel/Oil Ratio: 40:1
  • Fuel Tank Capacity: 14 oz. (414 ml)
  • Approximate Unit Weight (No fuel): 9 - 10 Ibs. (4.1 - 4.5 kg)
  • Air Volume (measured at: upper tube / general tube / special tube): 430 / 320 / 75 cfm (12 / 9 / 2 m3/min)
  • Air Speed (Peak) (measured at: upper tube / general tube / special tube): 90 / 145 / 200 mph (145 / 230 / 320 km/h)
  • Air Speed (Average) (measured at: upper tube / general tube / special tube): 75 / 120 / 160 mph (120 / 190 / 255 km/h)
Warranty
The Craftsman Blower 316.791600 comes with a limited warranty that lasts for two years from the date of sale. This warranty covers defects in material or workmanship. To claim the warranty, you need to provide proof of sale. If the product is found to be defective, you can either get it repaired or replaced for free, depending on the seller's option. However, it's important to note that the warranty only covers defects in material and workmanship. It does not include expendable items like spark plugs or filters that can wear out within the warranty period. Additionally, any product damage resulting from user attempts at modification or repair, or caused by product accessories, is not covered. The warranty is also void if the product is used for commercial services or rented to another person. To obtain free repair or replacement and to get more details about warranty coverage, you can visit the web page www.craftsman.com/warranty.
Craftsman 316.791600 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 970
