Up to 20% off select tools
1 Diagram
Documents
Models
921.153101
Background
The Craftsman Air Compressor 921.153101 is a device designed to convert power into potential energy stored in pressurized air. This compressor, manufactured by Midwest Air Technologies Inc. for Sears under the Craftsman Brand, is designed to provide a reliable source of compressed air for various applications.
The air compressor features an intake filter that provides clean air to the pump, a regulator gauge that indicates the outgoing air pressure to the tool, and a tank pressure gauge that indicates the reserve air pressure in the tank. Other features include a pressure switch that controls the power to the motor and the cut-in/cut-out pressure settings, a pressure relief valve designed to automatically release compressed air when the air compressor reaches cut-out pressure, and a tank drain valve used to drain condensation from the air tank. The air compressor also includes a quick connect feature for attaching and removing the air hose. The product is known for its durability, reliability, repairability, and longevity.
Technical Specifications
  • Model Number: 921.153101
  • Product: Craftsman Air Compressor 921.153101
  • Product Type: Air Compressor
  • Pump: Oil-lube direct drive
  • Motor: Induction, 1.5 HP max developed, 1 HP running
  • Bore: 1.65"
  • Stroke: 1.26"
  • Voltage: Single Phase, 120 VAC
  • Minimum Circuit Requirement: 15 Amps
  • Air Tank Capacity: 3 Gallons
  • Cut-in Pressure: 95 PSI
  • Cut-out Pressure: 125 PSI
  • SCFM @ 90 PSI: 2.4
Warranty
The warranty for the Craftsman Air Compressor 921.153101 is a one-year full warranty. If the air compressor fails due to manufacturer's defects in material or workmanship within one year of the date of purchase, it can be returned to the nearest Sears store or service center in the United States. The air compressor will then be replaced or repaired free of charge, at the option of the manufacturer. However, it's important to note that if the air compressor is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It is recommended to read the owner's manual for more information on how to claim the warranty.
Craftsman 921.153101 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 89
All Time: 1,446
