Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.17673
Background
The Craftsman Air Compressor 919.176730 is a versatile device designed for various applications requiring air pressure. Manufactured by Ingersoll Rand for Sears under the Craftsman brand, this air compressor features a 3 horsepower motor and a 20-gallon air tank. It operates on a dual voltage system, allowing for 120 or 240 volt operation. The air compressor has a displacement CFM (Cubic Feet per Minute) of 11.3, a bore of 2 5/8", and a stroke of 2".
The air compressor is designed to automatically restart when the tank pressure drops to a certain low level, known as the cut-in pressure, which is approximately 80 PSIG (Pounds per Square Inch Gauge). It also automatically shuts off when the air tank pressure reaches a certain high level, known as the cut-out pressure, which is approximately 100 PSIG. This device is capable of delivering 8.8 SCFM (Standard Cubic Feet per Minute) at 40 PSIG, 7.7 SCFM at 90 PSIG, and 7.3 SCFM at 100 PSIG. The Craftsman Air Compressor 919.176730 is a reliable and durable tool suitable for various air pressure requirements.
Technical Specifications
  • Model Number: 919.176730
  • Horsepower: 3
  • Displacement CFM: 11.3
  • Bore: 2.5"
  • Stroke: 2"
  • Voltage-Single Phase: 120/240
  • Minimum Branch Circuit Requirement: 15 amp
  • Fuse Type: Fusetron Type "T"
  • Air Tank Capacity (Gallons): 20
  • Approximate Cut-in Pressure: 80
  • Approximate Cut-out Pressure: 100
  • SCFM at 40 psig: 8.8
  • SCFM at 90 psig: 7.7
  • SCFM at 100 psig: 7.3
  • U.L Listed: Yes
Warranty
The Craftsman Air Compressor 919.176730 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails within one year from the date of purchase due to these issues, it can be returned to the nearest Sears Service Center/Department throughout the United States for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty period is shortened to ninety days from the date of purchase.
To claim the warranty, simply return the faulty air compressor to the nearest Sears Service Center/Department.
Please note that this warranty gives you specific legal rights, and you may also have other rights that vary from state to state.
Craftsman 919.176730 Owners Manual
Craftsman Air Compressor 2 HP 20 Gal Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 41
All Time: 946
