2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.16778
Background
The Craftsman Air Compressor 919.167780 is a portable air compressor manufactured by Ingersoll Rand for Sears under the Craftsman brand. This air compressor is designed to be permanently lubricated, eliminating the need for oil refills. It operates using a 2-stage Twin V motor, which is designed to provide a reliable and consistent supply of compressed air.
The air compressor uses a pressure switch that automatically starts the motor when the air tank pressure drops below a certain level, and stops the motor when the air tank pressure reaches a high level. It also includes a safety valve that protects against high pressure. The air compressor is capable of powering a variety of accessories, including caulk guns, ratchets, reciprocating saws, and more. It also features a cooling system that uses an engineered fan to expel air through the vent holes, indicating that the cooling system is working effectively. The air compressor pump compresses air into the air tank, providing working air once the compressor has raised the air tank pressure above the required level at the air outlet.
Technical Specifications
  • Model Number: 919.167780
  • Product Type: Air Compressor
  • Lubrication: Permanently Lubricated
  • Stages: 2-Stage
  • Design: Twin V
  • Portability: Portable
  • CFM: Cubic feet per minute
  • SCFM: Standard cubic feet per minute
  • PSIG: Pounds per square inch gauge
  • ASME Certified: Yes
  • Cut-in Pressure: Factory set low pressure
  • Cut-Out Pressure: Factory set high pressure
  • Branch Circuit: Circuit carrying electricity from electrical panel to outlet
  • Accessories Compatibility: Caulk Gun, 1/2" Ratchet, Reciprocating Saw, In Line Filter, Engine Cleaner, 3/8" Ratchet, Nibbler, Tire Air Chuck, Sand Blaster, 1/4" Ratchet, Spray Painting, Quick Connector Sets, Carpentry Tools, Material Shaping, Multi-Purpose Spray, Finishing Nailer / Stapler, 2.625" Hammer Gun, Air Pressure Regulators, Construction Nailer / Stapler, 1/2" Drill, Automotive Spray Gun, Oil Fog Lubricators, HVLP Spray Gun, Air Hose, Socket Driving, 3/8" Drill, Finishing/Sanding, 1" Impact Wrench, High Speed Rotary, High Speed Sander, 3/4" Impact Wrench, Mini High Speed Rotary, Random Orbit Sander, Specialty Tools, 1/2" Impact Wrench, Cut-Off Tool, 6" DA Sander, Inflating/Blow Gun, 3/8" Impact/Butterfly, Shear, Jitterbug Sander, Grease Gun, 4" Angle Grinder, Straight Line Sander
  • Carton Contents: 1 - Air Compressor, 2 - Wheels, 2 - Shoulder Bolts, 3/8-16, 2 - Hex Nuts, 3/8-16, 2 - Rubber Bumpers, 2 - Screws, 1/4-20 x .75
  • Assembly Tools Required: 1 - 9/16" socket or open end wrench, 1 - 1/2" socket or open end wrench
Warranty
The Craftsman Air Compressor 919.167780 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to these reasons within one year from the date of purchase, it can be returned to the nearest Sears repair center throughout the United States, and Sears will repair it free of charge.
If the air compressor was purchased from Orchard Supply Hardware, it should be returned to the nearest Orchard store for free repairs.
However, if the air compressor is used for commercial or rental purposes, the warranty coverage is reduced to ninety days from the date of purchase.
This warranty gives you specific legal rights, and you may also have other rights which can vary from state to state.
Craftsman 919.167780 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 45
All Time: 892
