No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.167463
Background
The Craftsman Air Compressor 919.167463 is a single-stage air compressor designed for a variety of applications. Manufactured by Ingersoll Rand for Sears under the Craftsman brand, this air compressor operates at 1.6 running horsepower. It features a bore of 2.875" and a stroke of 1.35". The unit operates on a single-phase 120V power source and requires a minimum branch circuit of 15 amps.
The air compressor has a 4-gallon air tank capacity and operates between an approximate cut-in pressure of 120 psi and a cut-out pressure of 150 psi. It can deliver 8.0 SCFM at 40 psig and 5.7 SCFM at 90 psig. These features make it a durable and reliable choice for various tasks that require compressed air. The Craftsman Air Compressor 919.167463 is designed for longevity and is repairable, making it a practical choice for long-term use.
Technical Specifications
  • Model Number: 919.167463
  • Running Horsepower (HP): 1.6
  • Bore: 2.875"
  • Stroke: 1.35"
  • Voltage-Single Phase: 120V
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity (Gallons): 4
  • Approximate Cut-in Pressure: 120
  • Approximate Cut-out Pressure: 150
  • SCFM @ 40 psig: 8.0
  • SCFM @ 90 psig: 5.7
Warranty
The Craftsman Air Compressor model 919.167463 comes with a full one-year warranty. This warranty covers any failures due to defects in material or workmanship. If the air compressor fails within one year from the date of purchase, Sears will either repair or replace it free of charge. To claim the warranty, you can contact your nearest Sears Service Center at 1-800-4-MY-HOME to arrange for repair, or return the air compressor to the place of purchase for replacement. Please note, if the air compressor is used for commercial or rental purposes, the warranty is valid for only ninety days from the date of purchase. This warranty provides specific legal rights, and you may also have other rights which can vary from state to state.
Craftsman 919.167463 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 348
