2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.167242
Background
The Craftsman Air Compressor 919.167242 is a tank-mounted air compressor designed for various applications. Manufactured by Ingersoll Rand for Sears under the Craftsman brand, it is a reliable and durable machine that can provide a steady supply of compressed air for different tasks.
The air compressor has a maximum developed horsepower of 3.0 and a running horsepower of 1.5. It operates on a single-phase voltage of 120V and requires a minimum branch circuit of 15 amps. The air tank has a capacity of 15 gallons, with an approximate cut-in pressure of 120 psi and a cut-out pressure of 150 psi. The air compressor can deliver 4.9 SCFM at 40 psig and 3.5 SCFM at 90 psig. This makes it suitable for a variety of uses, including powering air tools, inflating tires, and other tasks that require compressed air.
Technical Specifications
  • Model Number: 919.167242
  • Max. Developed HP: 3.0
  • Running HP: 1.5
  • Bore: 1.875"
  • Stroke: 1.25"
  • Voltage-Single Phase: 120V
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity: 15
  • Approx. Cut-In: 120
  • Approx. Cut-out: 150
  • SCFM @ 40 psig: 4.9
  • SCFM @ 90 psig: 3.5
Warranty
The Craftsman Air Compressor model 919.167242 comes with a full one-year warranty. If the air compressor fails due to a defect in material or workmanship within one year from the date of purchase, Sears will either repair or replace it for free. To claim this warranty, you can contact your nearest Sears Service Center at 1-800-4-MY-HOME to arrange for repair, or return the air compressor to the place of purchase for replacement. However, if the air compressor is used for commercial or rental purposes, the warranty applies for only ninety days from the date of purchase. This warranty provides you with specific legal rights, and you may have other rights that vary from state to state.
Craftsman 919.167242 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 12
Past 7 Days: 12
Past 30 Days: 48
All Time: 693
