2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
919.16561
Background
The Craftsman Air Compressor 919.165610 is a stationary air compressor model manufactured by Ingersoll Rand for Sears under the Craftsman brand. This model is designed with a permanently lubricated, two-stage, twin valve system. It is equipped with a variety of features including an On/Auto/Off switch, a pressure switch, a safety valve, a tank pressure gauge, a globe valve, a drain valve, a cooling system, an air compressor pump, a check valve, a pressure release valve, and an air intake filter.
The air compressor is used to compress air into the air tank, which can then be used to power various tools and accessories. The pressure switch automatically starts the motor when the air tank pressure drops below a certain level and stops the motor when the air tank pressure reaches a certain high level. The safety valve provides an additional level of protection by releasing pressure if the pressure switch fails to shut off the air compressor at its cut-out pressure setting. The air intake filter is designed to clean the air coming into the pump, ensuring efficient operation of the air compressor.
Technical Specifications
- Model Number: 919.165610
- Product Type: Air Compressor
Warranty
The Craftsman Air Compressor 919.165610 comes with a full one-year warranty. If the product fails due to a defect in material or workmanship within one year from the date of purchase, it can be returned to the nearest Sears Repair Center throughout the United States and Sears will repair it free of charge. If the product was purchased from Orchard Supply Hardware, it can be returned to the nearest Orchard Store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty will only apply for ninety days from the date of purchase.
To claim the warranty, simply return the faulty product to the nearest Sears Repair Center or Orchard Store, depending on where it was purchased from.
Please note that this warranty gives you specific legal rights and you may have other rights which vary from state to state.
Craftsman 919.165610 Owners Manual
Craftsman 919.165610 Stationary 2 Stage Twin Valve Air Compressor Operators Manual
