No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.16525
Background
The Craftsman Air Compressor 919.165250 is a product manufactured by Ingersoll Rand for Sears under the Craftsman brand. This air compressor is characterized by a one-cylinder, single-stage air compressor pump and an air tank. It includes wheels, a regulator, gauges, and a handle for easy transport. The compressor is permanently lubricated, eliminating the need for oil maintenance.
The product operates by compressing air as the piston moves up and down in the cylinder. When the piston is on a downstroke, air is drawn in through the air intake valves, and on the upstroke, air is compressed and forced out into the air tank. The product also features a check valve, pressure release valve, pressure switch, safety valve, regulator, outlet pressure gauge, and tank pressure gauge. The Craftsman Air Compressor 919.165250 is versatile and can be used for operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, or for inflating tires and plastic toys. It can also be used for spraying weed killers, insecticides, and more.
Technical Specifications
  • Model Number: 919.165250
  • Product Type: Air Compressor
  • Air Compressor Type: One cylinder, single-stage
  • Lubrication: No oil required
  • Pressure Measurement: PSIG (Pounds per square inch gauge)
  • Cut-In Pressure: Motor restarts automatically at a certain low pressure
  • Cut-Out Pressure: Motor shuts off automatically at a certain high pressure
  • Safety Standards: Meets applicable UL (Underwriters Laboratories, Inc.) Standards for Safety
  • Additional Features: Wheels, regulator, gauges, and handle
  • Potential Uses: Operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, inflating tires and plastic toys, spraying weed killers, insecticides, etc.
  • Air Filter: Removes moisture and dirt from compressed air
  • Size: Tank mounted
  • Maintenance: Permanently lubricated
Warranty
The Craftsman Air Compressor 919.165250 comes with a full one-year warranty from the date of purchase. This warranty covers any defects in material or workmanship. If the product fails due to these reasons within the warranty period, it can be returned to the nearest Sears Repair Center throughout the United States for a free repair. If the product was purchased from Orchard Supply Hardware, it should be returned to the nearest Orchard store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty period is reduced to ninety days from the date of purchase.
To claim the warranty, the defective product must be returned to the appropriate store (Sears or Orchard, depending on the place of purchase).
This warranty provides specific legal rights, and there may be other rights available, which can vary from state to state.
Craftsman 919.165250 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 47
All Time: 1,204
