No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.16509
Background
The Craftsman Air Compressor 919.165090 is a product designed to compress air for various uses. The device, manufactured by Ingersoll Rand for Sears under the Craftsman brand, consists of a one-cylinder, single-stage air compressor pump and an air tank. The compressor operates by moving a piston up and down in the cylinder, drawing in air on the downstroke and compressing it on the upstroke. This compressed air is then forced out through the exhaust valves and into the air tank.
The air compressor is equipped with several features to ensure its proper functioning. These include a check valve that allows compressed air to enter the air tank when the compressor is operating and closes when the compressor reaches "cut-out" pressure, a pressure release valve designed to automatically release compressed air from the compressor head and the outlet tube when the air compressor reaches "cut-out" pressure or is shut off, and a regulator that controls the air pressure coming from the air tank. The product is designed to be used for operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, or inflating tires and plastic toys.
Technical Specifications
  • Model Number: 919.165090
  • Product Type: Air Compressor
  • Air Compressor Type: One cylinder, single-stage air compressor pump and air tank
  • Lubrication: Does not require oil
  • Accessories Included: Wheels, regulator, gauges, and handle
  • Air Pressure Regulation: Comes with an air pressure regulator for various applications
  • Air Filter: Capable of removing moisture and dirt from compressed air
  • Applications: Can be used for operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, inflating tires and plastic toys, spraying weed killers, insecticides, etc.
  • Safety Standards: Meets applicable UL Standards for Safety
  • Cut-In Pressure: Motor restarts automatically when air tank pressure drops to a certain level
  • Cut-Out Pressure: Motor shuts off automatically when air tank pressure reaches a certain high level
Warranty
The Craftsman Air Compressor model 919.165090 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to these issues within one year from the date of purchase, it can be returned to the nearest Sears repair center throughout the United States for a free repair. If the product was purchased from Orchard Supply Hardware, it should be returned to the nearest Orchard store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty period is reduced to ninety days from the date of purchase.
To claim the warranty, the faulty product should be taken to the nearest Sears repair center or Orchard store, depending on where it was purchased.
This warranty provides specific legal rights, and there may be other rights available, which can vary from state to state.
Craftsman 919.165090 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 691
