No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.16415
Background
The Craftsman Air Compressor 919.164150 is a single-stage air compressor pump that includes a built-in air tank. Manufactured by Ingersoll Rand for Sears, this air compressor operates by moving a piston up and down in a cylinder. When the piston moves down, air is drawn in through the air intake valves. On the upstroke, the air is compressed and forced out through the exhaust valves, into the outlet tube, through the check valve, and finally into the air tank.
The compressor is designed to automatically start the motor when the air tank pressure drops below a certain level and stop the motor when the air tank pressure reaches a certain high pressure. This product also features a pressure release valve, a safety valve, a regulator, an outlet pressure gauge, a tank pressure gauge, and an advanced cooling system. The Craftsman Air Compressor 919.164150 can be used for a variety of applications including operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, and inflating tires and plastic toys.
Technical Specifications
  • Model Number: 919.164150
  • Product Type: Air Compressor
  • Air Compressor Type: One cylinder, single-stage
  • Oil Requirement: No oil required
  • Additional Components: Wheels, regulator, gauges, handle
  • Air Filter: Available for removing moisture and dirt from compressed air
  • Possible Uses: Operating paint spray guns, air tools, caulking guns, grease guns, air brushes, sandblasters, inflating tires and plastic toys, spraying weed killers, insecticides, etc.
  • Air Pressure Regulator: Included for various applications
  • Standards Compliance: ASME, UL Listed
  • Cut-In Pressure: Motor automatically restarts at a certain low pressure
  • Cut-Out Pressure: Motor automatically shuts off at a certain high pressure
Warranty
The Craftsman Air Compressor model 919.164150 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to such defects within one year from the date of purchase, it can be returned to the nearest Sears repair center throughout the United States for a free repair. If the product was purchased from Orchard Supply Hardware, it should be returned to the nearest Orchard store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty period is reduced to ninety days from the date of purchase.
To claim the warranty, the product needs to be returned to the place of purchase for repair.
This warranty provides specific legal rights, and there may be other rights available which vary from state to state.
Craftsman 919.164150 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 36
All Time: 1,114
