1 Diagram
Documents
Models
919.15309
Background
The Craftsman Air Compressor 919.153090 is a product designed and manufactured by Ingersoll Rand for Sears under the Craftsman brand. This air compressor is equipped with a bore of 1.86" (47.3 mm) and a stroke of 1.26" (32 mm), operating at a voltage of 120/60 with a minimum branch circuit requirement of 15 amps. The air tank capacity is 1.5 gallons (5.7 liters), and it operates within an approximate cut-in pressure of 120 PSIG and a cut-out pressure of 150 PSIG. The product is capable of delivering 3.0 SCFM at 40 psig and 2.0 SCFM at 90 psig.
The Craftsman Air Compressor 919.153090 is primarily used to power various accessories such as in-line filters, tire air chucks, quick connector sets, air pressure regulators, and oil fog lubricators. It is also equipped with a cooling system, an air compressor pump, and a check valve for efficient operation. The product's design includes a pressure switch for automatic control of the motor, a safety valve for high-pressure protection, and a regulator to control the air pressure. The air compressor also includes an outlet pressure gauge and a tank pressure gauge to monitor the available and reserve air pressure respectively.
Technical Specifications
  • Model Number: 919.153090
  • Product Type: Air Compressor
  • Bore: 1.86" (47.3 mm)
  • Stroke: 1.26" (32 mm)
  • Voltage/Hz-Single Phase: 120/60
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity: 1.5 Gallons (5.7 liters)
  • Approximate Cut-in Pressure: 120 PSIG
  • Approximate Cut-out Pressure: 150 PSIG
  • SCFM @40 psig: 3.0
  • SCFM @ 90 psig: 2.0
Warranty
The Craftsman Air Compressor 919.153090 comes with a full warranty. If the product fails due to a defect in material or workmanship within one year from the date of purchase, it can be returned to any Sears store, Sears Parts & Repair Service Center, or other Craftsman outlet in the United States for a free replacement. However, this warranty only applies for 90 days from the date of purchase if the product is used for commercial or rental purposes. The warranty provides specific legal rights, but other rights may also be available depending on the state. To claim the warranty, the product must be returned to a Sears store or other specified locations.
Craftsman 919.153090 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 879
