Up to 20% off select tools
2 Diagrams
Documents
Models
919.152145
Background and Identification
The Craftsman Air Compressor is a power tool intended to convert power into potential energy, which is stored in pressurized air. This device is manufactured in the USA. Similar products also can be bought in other countries. Air compressors produce compressed air as the most environmentally friendly power source in industrial production. It is widely used in medicine, food, machinery, electronics, plastics, textile, electric power, building materials, military industry, and so on, for spray, mixing, and transportation.
Some features attributed to the Craftsman Air Compressor:
  •   Pressure Switch
  •   Safety Valve
  •   Tank Pressure Gauge
  •   Outlet Pressure Gauge
  •   Cooling System
  •   Air Compressor Pump
The main color of this device is red and black. Its compressor is black, and its pump is red. In most situations, air compressors have a similar appearance, but this device is a portable direct-drive and oil-free electric air compressor. Its tank capacity is not big, which is 4 L.
Technical Specification
Dimension
  • Bore: 47.625
  • Stroke: 31.75
  • Air Tank Capacity: 4L
Power supply
  • Voltage-single Phase: 120V
  • Minimum Branch Circuit Requirement: 10amps
  • Fuse Type: Time Delay
  • Approx. Cut-in :120V
  • Approx. Cut-out: 150V
Rate of flow of the gas
  • SCFM @ 40 psig : 3.7
  • SCFM @ 90 psig : 2.6
Source: Air compressor usermanual
Additional Information
Craftsman 919.152145 Permanently Lubricated Tank-Mounted Air Compressor Owner's Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 87
All Time: 4,690
