Up to 20% off select tools
1 Diagram
Documents
Models
15206
Background
The Craftsman Air Compressor 15206 is a versatile tool that comes with an array of features. It operates on a 120V 60Hz, 2.6-amp motor with a running horsepower of 1/3 Hp. The compressor has a 3-gallon tank size and uses a 25' recoil air hose. The air delivery capacity of the compressor is 1.0 SCFM at 40 PSI and 0.6 SCFM at 90 PSI. The cut-in pressure is 85 PSI, and the cut-out pressure is 100 PSI, with the maximum pressure being 100 PSI. The power cord is 6ft long with a 3-prong, 18 AWG. The unit weighs 18.691b (8.5kg).
The Craftsman Air Compressor 15206 is used for a variety of tasks that require air compression. It can be used to power pneumatic tools, inflate tires or other inflatable objects, and for cleaning purposes. It is capable of running continuously, but to prolong its life, it is recommended that a 50%-75% average duty cycle is maintained. This means that the air compressor pump should not run more than 30-45 minutes in any given hour. The compressor comes with accessories such as a brad nailer, nails, 25' recoil air hose, inflation needle, tapered blow gun nozzle, blow gun adapter, blow gun safety nozzle, blow gun, tire chuck, 1/4" male quick-connect plugs, PTFE-thread seal tape, 1/4" female quick-connect body, hex wrench, and oil.
Technical Specifications
  • Model Number: 15206
  • Product Type: Air Compressor
  • Motor: 120V 60Hz, 2.6-amp
  • Running Horsepower: 1/3 Hp
  • Tank Size: 3-gallon
  • Air Hose Type: 25' recoil, MAX.
  • Air Delivery: 1.0 SCFM @ 40 PSI, 0.6 SCFM @ 90 PSI
  • Cut-in Pressure: 85 PSI
  • Cut-out Pressure: 100 PSI
  • Max. Pressure: 100 PSI
  • Power Cord: 6ft, 3-prong, 18 AWG
  • Unit Weight: 18.691b (8.5kg)
Warranty
The Craftsman Air Compressor 15206 comes with a full warranty. If the product fails due to a defect in material or workmanship within one year from the date of purchase, it can be returned to any Sears store or other Craftsman Evolv outlet in the United States for a free replacement.
However, the warranty does not cover expendable parts such as o-rings or driver blades that can wear out from normal use within the warranty period. Also, the warranty becomes void if the product is used for commercial or rental purposes.
To claim the warranty, simply return the faulty product to a Sears store or other Craftsman Evolv outlet.
Please note that this warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
Craftsman 15206 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 77
All Time: 2,333
