Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The COSMED microQuark is a PC-based spirometer that allows medical professionals to perform screening spirometry in a compact and portable package. In combination with the included software, the COSMED microQuark provides accurate and thorough results thanks to its comprehensive interpretation algorithm that provides easy-to-interpret results.
Identification
The COSMED microQuark is a small handheld device with a singular USB cable running out the bottom of the handle portion of the device. The microQuark can be distinguished from COSMED’s other spirometers due to the handheld nature of the device as well as the attached cable. Furthermore, the print “COSMED” and “microQuark” will be visible on the air intake portion of the device.
Technical Specifications
Standard Tests (Spirometry)
Tests: Forced Vital Capacity (FVC) Pre/Post, Slow Vital Capacity (SVC) Pre/Post, Maximum Voluntary Ventilation (MVV), Bronchial challenge - Bronchial Dilator/Constrictor test
Measured Parameters: (partial listing) FVC • IVC • VC • MVV • VT • FEV1 • FEV6 • FEV1/FEV6 • FEV6/FVC • PEF • PIF • FEV1/FVC • FEF 25-75 • FEV1/VC% • %FEV1 • MEF25% • MEF50% • MEF75% • FET 100% • Lung Age • ERV • IRV • VE • Rf • ti • te • ti/t.tot • VT/ti • Best FVC • Best FEV1 • IC
Predicted Values: (partial listing) GLI, ERS 93, NHANES III, Knudson 83, ITS, Zapletal, LAM, Pneumobil, Gutierrez (Chile), Multicèntrico Barcelona, Thai 2000, Austria (Forche), Crapo 1981
Interpretation: Automatic and comprehensive, with statements based on: ATS/ERS 2005 (Spirometry), GOLD COPD, ATS/ERS 2005 (Obstruction Reversibility based on FVC Post BD), ATS/ERS 2007 (Obstruction Reversibility based on Rocc)
Hardware
Dimensions & Weight: 150 x 45 x 53 mm / 77 gr
Interfaces: USB
Power supply: via USB
Flowmeter Turbine Ø-28mm
Type: Bidirectional Digital Turbine
Resolution: 12 ml
Ventilation Range: 0-300 l/min
Flow Range: 0-16 l/s
Accuracy: ± 2% or 20 ml/s
Resistance: <0.8 cmH2 O /l/s @ 14l/s
Software OMNIA
Available languages: Italian, English, Spanish, French, German, Portuguese, Greek, Dutch, Turkish, Russian, Chinese (Traditional & Simplified), Korean, Romanian, Czech, Norwegian
Required PC Configuration: I3 or higher processor speed. Compatible with Windows 7, 8, 8.1, 10 (32 or 64 bit). RAM 4GB (8GB recommended). HD with 4GB of free space (plus tools)
Sources
Additional Information
Product Brochure
Antiviral/Antibacterial Filters
COSMED Products Comparison Matrix
microQuark Bibliography
COSMED microQuark Espirómetro para PC — Folleto
COSMED microQuark Espirómetro USB para PC — Folleto
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 60
All Time: 1,901
