Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Compatibility and Speed The 1571 was optimized for the C128’s fast burst-mode interface, allowing it to load software much faster than the older 1541. When used with a Commodore 64, it automatically switches to a 1541-compatible mode, and while it mostly works well, there are some specific, complex copy-protection techniques on C64 games that can fail on a 1571. It’s also surprisingly versatile, able to handle the MFM formats used by CP/M disks, making it indispensable for that part of the C128's ecosystem.
Notable Internal Design Unlike some earlier Commodore drives, the 1571 uses an internal switching power supply, which helped keep the unit compact but also means troubleshooting power issues requires appropriate safety precautions with high-voltage components. The core of the drive is controlled by its own 6502 microprocessor running at 1MHz, effectively making it a complete computer specialized just for handling disk access.
Common Maintenance and Malfunctions The single biggest maintenance requirement for a vintage 1571 is lubricating the mechanical parts. If you are getting frequent "FILE NOT FOUND" or "DRIVE NOT READY" errors, the problem is very often dry, sticky grease on the stepper motor rails preventing the read/write head from moving correctly. Clean off the old grease with alcohol and apply a plastic-safe lubricant. Also, as these units age, the read/write heads often need gentle cleaning, and you should watch out for the failure of the original 6522 CIA chips on the board, which can cause erratic read/write behavior or make the drive unresponsive. Finally, because this is a double-sided drive, it has a second head that is inherently more delicate than the single head in a 1541, so handle with care during disassembly.
(ai again sorry. pls fix i suck at writing)
Commodore 1571 Disk Drive Preliminary Service Manual
Commodore TechTopics Issue 20
Commodore TechTopics Issue 29 (April–June 1990)
Author
with
RaskAttack
535 Reputation
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 70
All Time: 351
