Up to 20% off select tools
Guides
2 Diagrams
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
OBS-18DC Square Buff Orbital Sander General Maintenance and Service Video
Background and Identification
The American Sanders Floor Sander is a square floor sander manufactured by Nilfisk, a Denmark-based company that manufactures professional cleaning equipment. Nilfisk produces equipment that is suitable for the industrial market as well as consumer and commercial markets. Clarke began in 1916 as a maker of floor sanders as well as other vacuums and cleaning equipment. It was bought by Studebaker Company in the 1960s and later by Nilfisk. It is now a regional brand within the Nilfisk company.
The Clarke Floor Sander is intended to be used on wood flooring, but can also be operated on tile flooring or Terrazzo, a composite flooring made of chips of various rocks and minerals. The square shape of the abrasive pad allows the sander to effectively work in the corners of a room.
The sander uses a moving abrasive pad to remove the upper layer of a flooring. Before using a floor sander, it is important to remove any nails, staples, or tacks that are in the floor, as this can seriously damage the sander.
Technical Specifications
  • Code Number: 07014A
  • Shipping Weight: 125 lbs.
  • Pad Size: 12" x 18"
  • Orbits Per Minute: 3600
  • Orbit Diameter: 1/4 inch
  • Voltage/Frequency: 115V/60Hz
  • Amperage (A): 10
  • Noise (dBA): 74
  • Vibration (m/s/s): 11.2
  • Motor: 1 hp
  • Power Cable: 40' 12-3 GA Gray, Rubber Jacketed
Additional Information
Clarke 07014A Operating Manual
Nilfisk Home Page
Floor Sanding - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 14
Past 7 Days: 111
Past 30 Days: 643
All Time: 58,349
