2 Answers 0 Score |
Why do my front tires wear out so fast? |
2 Answers 0 Score |
Blinker not blinking it just stays solid |
Documents
Chevrolet HHR Technical Specs
Engine and Performance
- 2.2L Ecotec I4 (Base): Produced 143 hp to 155 hp depending on the year; a reliable, high-volume engine found in many GM compacts.
- 2.4L Ecotec I4 (LE5): Offered as an upgrade on the LT trim, producing 172 hp to 175 hp and 167 lb-ft of torque.
- 2.0L Turbocharged Ecotec (SS Model): The high-performance "Super Sport" variant delivered a significant jump to 260 hp and 260 lb-ft of torque, capable of 0-60 mph in approximately 6.3 seconds.
Drivetrain and Transmission
- Transmission Options: A 5-speed manual (Getrag) or a 4-speed automatic (4T45-E).
- SS Performance Tech: The SS model featured a unique "No-Lift Shift" program in the manual version and an optional Limited Slip Differential (LSD).
- Brakes: Base models utilized front discs and rear drums, while the SS model was upgraded to 4-wheel discs with optional Brembo front calipers.
Chassis and Versatility
- Suspension: Independent MacPherson struts in the front and a semi-independent torsion beam in the rear. The SS trim featured a "FE5" performance-tuned suspension.
- Cargo Capacity: The HHR was highly praised for its flat-folding front passenger seat and "Easy-Clean" plastic cargo floor, providing up to 57.7 cubic feet of storage space.
- Panel Van Variant: A unique "Panel" version was available for commercial use, featuring windowless side panels and rear "cargo doors" without exterior handles, operated via a dashboard release or key fob.
Dimensions
- Wheelbase: 103.5 inches (2,629 mm).
- Length: 176.2 inches (4,475 mm).
- Curb Weight: Approximately 3,155 lbs for base models.
