Up to 20% off select tools
Potential Student Project
This page has been tagged for revision by students in our education program.
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Student In Progress
This wiki is being worked on by hardworking students.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Cardiac Science Powerheart AED G3 Pro is an automated external defibrillator engineered for both professional emergency responders and advanced life support (ALS) personnel. This device is optimized for medical flexibility by acting as both a semi-automatic savior for general users and a full manual monitor for medical specialists.
Introduced after receiving FDA 510(k) clearance in 2004, the G3 Pro expanded on Cardiac Science’s original Powerheart line by adding non-diagnostic 3-lead ECG monitoring and manual shock controls. The device later received FDA Premarket Approval (PMA) in 2018 under updated federal defibrillator regulations. Although Cardiac Science—now part of ZOLL Medical Corporation—has officially discontinued the G3 Pro in favor of newer models like the Powerheart G5, replacement batteries and electrode pads remain widely available so existing units can stay in service. Between 2009 and 2012, the FDA issued Class I and Class II recalls for certain Powerheart G3 Pro (9300P) units due to circuit-board component defects and self-test errors (0x48 and 0x99) that could prevent shock delivery. All affected recalls have since been terminated following manufacturer repairs and replacements.
To check whether a specific Powerheart AED G3 Pro Model 9300P was part of a recall and left un-repaired, owners must cross-reference the unit's serial number against official FDA recall notices and verify its service history with ZOLL Medical (the current parent company of Cardiac Science).
The G3 Pro features advanced diagnostic automation and a robust, weather-resistant enclosure. This model is widely deployed across corporate safety fleets, healthcare networks, and first responder vehicles globally.
The AED is a self-testing, battery-operated automated external defibrillator (AED). After applying the AED’s defibrillation pads to the patient’s chest, the AED automatically analyzes the patient’s electrocardiogram (ECG) and advises the operator to push the button and deliver a shock if needed. The AED guides the operator through the rescue using a combination of voice prompts, audible alerts, and visible indicators. At the discretion of Advanced Life Support (ALS) personnel, the AED can be converted to manual override mode, and deliver a shock by pushing the SHOCK button. The AED can also provide non-diagnostic ECG monitoring.
Identification
You can identify your specific device variant by checking the manufacturing label or the hardware interface configurations:
  • Model Number: Look for the 9300P or Powerheart AED G3 Pro text directly on the front casing or printed on the regulatory serial sticker beneath the device.
  • Color Scheme: The G3 Pro appliance is finished in a high-visibility signature yellow.
  • Handle and Accents: The carrying handle is integrated into the top of the chassis and the device contains protective side bumpers.
Technical Specifications
Device Metrics
  • Dimensions: 3.3 in x 10.6 in x 12.4 in (8.4 cm x 26.9 cm x 31.5 cm)
  • Weight: 7.0 lbs (3.2 kg) including battery pack and electrode pads
  • Ingress Protection Rating: Rated at IP24 for enclosure resistance, ensuring protection against object infiltration greater than 12.5mm and direct splashes of water from any direction.
Waveform & Energy Output
  • Waveform: Proprietary STAR Biphasic Truncated Exponential (BTE) variable waveform utilizing three discrete therapeutic settings: ultra-low variable energy, low variable energy, and high variable energy. The system dynamically alters pulse structures based on measured patient resistance; across a 25 to 125 Ohm range, Phase 1 duration automatically scales from 3.3 ms to 8.3 ms while initial phase voltages escalate up to 1945V to guarantee optimal energy delivery.
  • Energy Output: Factory default 200-300-300 Joule (J) escalating Variable Energy (VE). The first shock delivers a range of 140J–250J (200J nominal), and subsequent shocks deliver a range of 190J–360J (300J nominal) based on measured thoracic impedance.
  • Operating Impedance Range: Patented STAR Biphasic technology dynamically customizes shocks across a patient impedance range of 25–180 Ohms.
Power & Battery Specifications
  • Operational Modes: Semi-automatic with a manual defibrillation override feature for advanced life support (ALS) users.
  • Power Source: Field-replaceable, non-rechargeable Intellisense lithium sulfur dioxide battery pack (Model 9145). Features an output voltage of 12VDC, a 5-year standby shelf life, and a full operational guarantee of 1 year or 12 hours of use (delivering up to 290 shocks). Contains 9.2g of lithium.
WARNING! — EXPLOSION AND FIRE HAZARD: The primary Intellisense battery pack (Model 9145) is strictly NON-RECHARGEABLE. Do not attempt to recharge this battery under any circumstances, as doing so poses an immediate risk of explosion or fire. Only the optional alternative battery companion accessory (Model 9144) is rechargeable.
  • Capacitor Charge Performance: Ramps to maximum energy in approximately 10 seconds (even after 15 consecutive 300VE discharges). Maximum combined timeline from initial rhythm analysis to shock deployment is under 17 seconds.
Rescue Elements & Diagnostics
  • Rescue Data Storage: Internal memory records up to 60 minutes of continuous ECG patient data accompanied by comprehensive event annotations.
  • Electrode Pads: Self-adhesive disposable design featuring a combined minimum active surface area of 228 cm² and an extended insulated lead wire length of 1.3 meters.
  • Environmental Limits: Certified for functional operation and standby deployment within a temperature range of 32°F to 122°F (0°C to 50°C) and non-condensing humidity levels between 5% and 95%.
  • Diagnostic Automation (Self-Tests):
    • Daily: Core system verification of battery capacity, pad presence, software integrity, internal circuit pathways, and the mechanical shock button.
    • Weekly: All daily verification metrics combined with an automated partial-energy capacitor charge cycle test.
    • Monthly (Every 28 Days): All weekly testing metrics combined with a full-energy charge test administered while loading the battery subsystem.
    • Lid Operations: Instant internal diagnostics are automatically initiated upon every open or close cycle of the device lid housing.
Troubleshooting Common Issues
When your Cardiac Science Powerheart AED G3 Pro displays a warning light or emits an acoustic beep every 30 seconds, opening the lid triggers an immediate internal diagnostic to identify the error via voice prompts or text displays.
  • Clearing Beeps & Resets: Opening and closing the lid temporarily silences maintenance beeps, though unresolved errors return during the next self-test. To force a manual initialization cycle, insert the battery, open the lid for 5 seconds, and close it.
  • Smartgauge Battery Low Warning: As capacity drops, green charge bars recede from right to left before turning solid RED with a "BATTERY LOW" prompt. Despite the warning, the internal capacitor retains enough power to deliver at least 9 additional shocks.
  • Z-Bar Impedance Range: The G3 Pro uses a 5-section graphical layout called the Z-Bar to monitor transthoracic impedance:
    • Section 1 (< 20 Ohms): Lower Limit Alarm (Pads shorted, Red)
    • Section 2 (20–30 Ohms): Lower Marginal Range (Overlapping pads, Yellow)
    • Section 3 (30–150 Ohms): Ideal Operating Range (Nominal contact, Green)
    • Section 4 (150–180 Ohms): Upper Marginal Range (Pad degradation, Yellow)
    • Section 5 (> 180 Ohms): Upper Limit Alarm (Pads detached, Red)
  • Analysis Interrupted: If the screen reads "ANALYSIS INTERRUPTED. STOP PATIENT MOTION," eliminate physical movement and keep the AED at least 6 feet (2 meters) away from RF transmitters or cell phones.
  • Advanced Life Support (ALS) Manual Override: Lift the left panel cover and press the MANUAL button, then confirm the prompt within 30 seconds to engage manual mode; otherwise, the device safely dumps the charge and reverts to standard automated mode. This should only be used by ALS Personnel such as paramedics, nurses or physicians as it converts the device from an automated external defibrillator (AED) into a manual monitor and defibrillator
Additional Information
For further details regarding operation, testing frequency, and parts replacement, refer to the following official replacement lifespan resource: AED Professionals
power Heart AED G3 Pro — Official diagnostic summary, parts catalog, and device overview.
OPERATOR AND SERVICE MANUAL POWERHEART AED G3 PRO 9300P — Full English-language technical documentation providing factory specifications, operational procedures, and step-by-step diagnostic checks.
Powerheart AED G3 Pro 9300P — Manual de uso y mantenimiento — The official Spanish-language variant of the master operations manual, covering real-time screen prompt translations and automated warning code breakdowns.
Powerheart AED G3 Trainer Hoja de información del producto — Spanish-language product data sheet detailing capabilities, configuration settings, and structural dimensions for the simulation-only device variant.
Cardiac Science Powerheart AED G3 Pro 9300P — Manual de Serviço e do Operador — Official Portuguese translation of the maintenance guide, detailing calibration protocols, specialized testing equipment configurations, and warranty rules.
Cardiac Science Powerheart AED G3 Pro 9300P — Manuale d'uso e assistenza — Official Italian-language service documentation specifying system initialization steps, internal hardware architecture layout, and battery management parameters.
Cardiac Science Powerheart AED G3 Pro Operator and Service Manual — Provides complete technical diagnostic protocols, circuit pathway blueprints, and official troubleshooting code definitions directly from the manufacturer.
Cardiac Science Powerheart G3 Pro AED Accessory Replacement Kit — Provides official manufacturer-recommended replacement components including polarized adult pads, pediatric pads, and high-capacity non-rechargeable batteries to maintain device readiness.
Required Parts & Maintenance Bundles
For routine servicing, users can utilize a Cardiac Science Powerheart G3 PRO AED Refresh Pack to replace all expired components simultaneously. These maintenance kits typically bundle the critical field-replaceable elements:
  • Intellisense Lithium Battery: Model 9145 (Non-rechargeable)
  • Polarized Adult Defibrillation Electrode Pads: Part #9131-001
  • Alternative Manufacturer Bundle SKU Variants: ARP-G3PRO-BAS (Basic), ARP-G3PRO-STD (Standard), and ARP-G3PRO-COM (Complete)
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 92
All Time: 297
