Up to 20% off select tools
Background Information
CPU coolers are components designed to dissipate heat generated by your computer's Central Processing Unit (CPU). Typically, CPU coolers consist of a heatsink, heat pipes, a fan, or multiple fans to efficiently transfer heat away from the CPU.
Types of CPU Coolers
Air Coolers
Air coolers are a cooling solution designed to dissipate heat generated by a CPU (Central Processing Unit) within a computer system. These coolers consist primarily of a heatsink and a fan or multiple fans attached. The heatsink absorbs the heat from the CPU, and then the fan(s) blow air over the fins, facilitating the transfer of heat away from the CPU and into the surrounding air.
ProsCons
Air Coolers are ideal for general PC users thanks to their low cost, and their ability to displace hot air.Air Coolers can be more bulky compared to other cooling options and are not as efficient when placed under heavy processing loads. Air Coolers also run at a higher RPM, causing them to be louder when under a heavy processing load.
U-Type/Twin Tower Air Coolers
U-Type or Twin Tower air coolers are CPU cooling solutions known for their dual tower design, which enhances heat dissipation. These coolers consist of two heat dissipation towers connected by heat pipes. The heat pipes facilitate the transfer of heat from the CPU to the heatsink towers, where it is dispersed into the surrounding air.
The dual tower design increases the surface area for heat dissipation, allowing for more efficient cooling. These coolers typically feature multiple fans positioned to direct airflow through the heatsink towers, further enhancing their cooling performance.
One of the benefits of U-Type or Twin Tower air coolers is their ability to effectively cool high-powered processors, maintaining optimal operating temperatures even under heavy workloads or during overclocking. They are also known for their durability and reliability, making them suitable for long-term use in various computing environments.
C-Type Air Coolers/Top-Down Coolers
C-Type air coolers, often referred to as top-down coolers, are CPU cooling solutions engineered to dissipate heat by directing airflow directly onto the CPU and nearby components. In contrast to tower-style air coolers, which are vertically oriented, C-Type coolers have a horizontal design. This design sees the heatsink extending over the CPU socket, forming a shape reminiscent of the letter "C."
The horizontal orientation of C-Type coolers allows them to effectively blow air onto the CPU and surrounding components, such as VRMs (Voltage Regulator Modules) and RAM modules. These coolers can efficiently dissipate heat and maintain optimal operating temperatures for the CPU and other critical components.
C-Type air coolers offer several advantages due to their design. They can provide effective cooling for CPUs in systems with limited vertical clearance, such as small form factor (SFF) builds or low-profile cases. Their horizontal airflow can also help cool other components near the CPU socket, contributing to overall system stability and longevity.
Low-Profile Air Coolers
Low-profile air coolers cater to the specific cooling needs of compact computer cases or systems constrained by limited vertical clearance, including small form factor (SFF) builds and Home Theater PCs (HTPCs). These cooling solutions are engineered with a slim and compact design, ensuring they can comfortably fit within tight spaces while still delivering sufficient cooling performance for the CPU.
The defining feature of low-profile air coolers is their slim and low-profile heatsink, which is designed to occupy minimal space within the computer case. This slim profile allows the cooler to fit snugly even in cases with limited vertical clearance, where standard-sized coolers may struggle to accommodate.
Passive Air Coolers
Passive air coolers have no moving parts and do not incorporate a fan. They cool by either of two mechanisms:
Some coolers are designed to transfer heat to the surrounding still air by convection. The advantage of this type is that they are completely silent, but they are limited in their heat-dissipation capacity. A few companies produce very large passive tower coolers with fins widely spaced to maximize convection. In addition, in a retrocomputing context, CPU coolers often consist of a simple heatsink, as CPUs of that era dissipated minimal power.
Other passive coolers rely on separate fans located elsewhere in the chassis to direct airflow over the coolers' fins. The chassis design, often incorporating plastic shrouds, ensures that a row of fans directs air over multiple heat-generating components, including the CPU, drives, and RAM, as it passes through the computer. This type is mainly used in 1U and 2U servers, but has occasionally been used in pre-built desktops.
Liquid Coolers
Liquid or Water Coolers are advanced cooling solutions designed to efficiently dissipate heat generated by a CPU in a computer system. Unlike air coolers, which use air to transfer heat away from the CPU, liquid coolers use a closed-loop liquid coolant system to achieve this goal. Liquid Coolers typically consist of a waterblock, pump, radiator, tubing, and liquid coolant.
ProsCons
Liquid Coolers run at a lower RPM, which makes them quieter when under a higher processing load. Some Liquid Cooling options also allow for a great deal of versatility and can be integrated into any system.As the name implies Liquid Coolers use liquid, which could result in the processing system or other components becoming liquid damaged While All-in-One Liquid Coolers have attempted to combat this issue, custom Liquid Cooling can leak if not properly set up.
Closed-Loop
Closed-loop liquid coolers, commonly known as all-in-one (AIO) liquid coolers, represent a sophisticated advancement in CPU cooling technology. These cooling solutions harness a closed-loop system to efficiently transfer heat away from the CPU, ensuring optimal thermal management for high-performance computing systems. Unlike custom liquid cooling setups, which demand the meticulous assembly of individual components such as reservoirs, pumps, tubing, and radiators, closed-loop liquid coolers arrive pre-assembled and sealed, offering users a hassle-free installation experience with minimal maintenance requirements.
The closed-loop design of these coolers simplifies the installation process, making them accessible even to users with limited technical expertise. With no need for complex tubing configurations or coolant refills, users can quickly and easily mount the cooler onto their CPU socket, significantly reducing setup time and effort. This plug-and-play functionality ensures that users can enjoy the benefits of liquid cooling without the complexities associated with custom setups.
Furthermore, the sealed nature of closed-loop liquid coolers eliminates concerns regarding leaks or system maintenance commonly associated with custom liquid cooling solutions. By encapsulating the coolant within a sealed loop, these coolers mitigate the risk of fluid loss or contamination, ensuring long-term reliability and peace of mind for users.
Despite their simplified design and installation process, closed-loop liquid coolers offer impressive cooling performance comparable to custom liquid cooling setups and superior to traditional air coolers. By leveraging the efficiency of liquid cooling technology, these coolers effectively dissipate heat from the CPU, enabling users to achieve lower operating temperatures and improved system stability, particularly during demanding computing tasks or overclocking scenarios.
Custom Loop
Custom loop liquid coolers, also referred to as custom liquid cooling setups, represent the pinnacle of CPU cooling solutions, renowned for their exceptional cooling performance and unparalleled customization options. Unlike closed-loop liquid coolers, which arrive pre-assembled and sealed, custom loop liquid coolers are meticulously crafted from individual components, offering users complete control over every aspect of their cooling system. This includes a pump, reservoir, radiator, water blocks, tubing, fittings, and coolant, each carefully selected to meet the user's specific needs and preferences.
The modular nature of custom loop liquid coolers empowers users to tailor their cooling solution to suit their unique requirements, whether it be maximizing cooling performance, achieving a specific aesthetic vision, or accommodating the demands of overclocking. By hand-selecting each component, users have the flexibility to optimize their cooling loop for efficiency, reliability, and style.
At the heart of every custom loop liquid cooler is the pump, responsible for circulating the coolant throughout the system. Users can choose from a variety of pump options, including standalone units or integrated pump-reservoir combos, each offering different levels of performance and customization potential. The reservoir serves as a centralized reservoir for the coolant, providing convenient access for filling, bleeding, and monitoring fluid levels.
The radiator, a critical component of the cooling loop, acts as a heat exchanger, dissipating heat from the liquid coolant into the surrounding air. Radiators come in various sizes, thicknesses, and configurations, allowing users to tailor their cooling system to fit within their case and meet their thermal dissipation requirements.
Water blocks, mounted on the CPU and other heat-generating components, facilitate the transfer of heat from the source to the liquid coolant. These blocks come in different designs and materials, such as copper or nickel-plated copper, each offering different levels of thermal conductivity and aesthetics.
Tubing and fittings connect the various components of the custom loop, allowing the coolant to flow seamlessly throughout the system. Users can choose from a wide range of tubing materials, including soft tubing (e.g., PVC, silicone) or rigid tubing (e.g., acrylic, PETG), as well as fittings in various sizes, angles, and finishes to accommodate their specific configuration and aesthetic preferences.
Finally, coolant selection allows users to personalize the appearance of their custom loop liquid cooler, with a wide array of colors and formulations available to match their build theme and style.
Additional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 138
All Time: 4,379
