Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Troubleshooting
If you are having difficulties with the CAT S48c phone, refer to the troubleshooting page here.
Background
This is a phone created by CAT, model S48c, released on November 09, 2018. The CAT S48c is designed to withstand harsh environments, so it is often used in construction and other jobs where it would be important for a phone to have strong protection. This device is a result of the partnership of CAT, the heavy equipment company, and Bullit Mobile.
Distinguishing features of the model are its compact size and tough exterior to survive construction-type environments, but it also has normal phone key functions like a headphone jack, speaker, usb port, camera, and flashlight.
The CAT S48c has an IP68 rating, which is a rating given to phones with high resistance to dust and water (can be submerged up to 4 feet of water for up to 35 minutes). It met MIL-STD-810G military standards, certifying it's high resistance to shock, vibration, dust, humidity, and extreme temperatures. The CAT S48c's display is protected by the Corning Gorilla Glass 5, a screen protector that comes with the phone, and can be operated with gloves or wet fingers.
Major facts:
The CAT S48c is good for drops of 6 feet high with only taking minimal to no damage.
It is not disposable as normal garbage
Identification
On the back of the phone is the CAT logo that is indented into the case. Underneath the logo, there is some small text that says:
CID2. Gr A-D, T4, TAMB: -25°C TO +55°C
WARNING-EXPLOSION HAZARD  DO NOT CHARGE OR CONNECT OR REMOVE ANYTHING IN HAZARDOUS AREAS
About the size of a standard iPhone, pre-installed screen protector and a black case.
Technical Specifications
  • Phone Weight: 9.1 oz  (258 g)
  • Phone Dimensions: 5.9 x 3.0 x 0.5 In
  • Screen Display Specs
    • Display Size: 5 In
    • Display Type: LCD
    • Resolution: 1920 x 1080
  • Phone is Waterproof (Up to 4 feet of water for 35 minutes)
  • System chip: Snapdragon 630 SDM630 (14 nm)
  • CPU: Octa-core 2200 MHz ARM Cortex-A53
  • GPU: Adreno 508
  • Memory: 4GB (LPDDR4)/32GB
  • Storage expansion: microSDXC up to 128 GB
  • OS: Android (8.1 Oreo)
  • Camera Specs
    • Front camera: 5MP, Fixed focus
    • Rear Camera: 13MP, Auto Focus, Supports Underwater Photography
Additional Information
This device is a phone made for extreme environments, while it being strong and durable, it is also waterproof making it able to get wet and still work without any problems.
Author
with
RYAN RAMIREZ
302 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 467
