Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Background and Identification
The Zeppelin Air is a portable speaker released by British audio equipment company Bowers & Wilkins. The speaker is equipped with Apple’s AirPlay and can dock Apple devices as well as wirelessly stream music from Apple devices that use iTunes. The speaker can be connected to a TV to display photos and video from the linked Apple device.
The Zeppelin Air contains an amplifier for each of its five speakers: two tweeters, two midrange woofers, and a subwoofer.
Specifications
Drive Units: 2x 25mm (1.0in) Nautilus™ tube aluminum tweeter, 2x 75mm (3.0in) Midrange, 1x 125mm (5.0in) Subwoofer
Frequency Response: 51Hz – 36kHz ±3dB on reference axis
Frequency Range: -6dB at 36Hz and 42kHz
Amplifier Power Output: 2x 25W (tweeter), 2x 25W (midrange), 1x 50W (subwoofer)
Input Voltage: 100V - 240V ~ 50/60Hz
Rated Power Consumption: 100W
Standby Power Consumption: 0.8W
Inputs: iPod/iPhone (30-pin connector or Lightning connector), Network (RJ45 Ethernet or Wi-Fi), Auxiliary-analogue/optical digital (3.5mm mini jack), Streaming, synchronization & firmware upgrades (USB 2.0)
Outputs: Composite Video (RCA Phono)
Height: 173mm (6.8in)
Width: 640mm (25.2in)
Depth: 208mm (8.2in)
Net Weight: 6.2kg (13.5lb)
Enclosure: Gloss black with stainless steel trim
Grilles: Black cloth
Airplay Compatibility: iPhone, iPod touch and iPad with iOS 4.3.3 or later, Mac with OS X Mountain Lion, or Mac and PC with iTunes 10.2.2 or later
30-pin Connector Compatibility: iPhone 4, iPhone 3GS, iPhone 3G, iPhone, iPod Touch (4th, 3rd, 2nd and 1st generations), iPod Classic and iPod nano (6th, 5th, 4th, 3rd and 2nd generations)
Lightning Connector Compatibility: iPhone 5, iPod Touch (5th generation), and iPod nano (7th generation)
(Bowers & Wilkins Zeppelin Air Specifications)
Additional Information
Bowers & Wilkins Support: Zeppelin Air
Crutchfield: Zeppelin Air
Wikipedia: Bowers & Wilkins
Amazon: Zeppelin Air
Sam Goldheart
478,127 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
Past 24 Hours: 10
Past 7 Days: 49
Past 30 Days: 205
All Time: 63,708
