Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Overview
The Bose Portable Smart Speaker is a wireless, portable, voice-controlled, Bluetooth speaker. When the speaker is connected to a Wi-Fi network, you can stream music directly from the cloud, however, you can control the speaker like any other portable speaker when outside a network.
Technical Specifications
Physical Dimensions
  • Height: 7.5" (19.15 cm)
  • Width: 4.7" (11.9 cm)
  • Depth: 4" (10.4 cm)
  • Weight: 2.34 lbs (1.06 kg)
Materials/Finishes
  • Finish:
    • Triple Black
    • Lix Silver
  • Seamless aluminium grille
  • Woven carry handle
Power
  • Battery Chemistry: Lithium-Ion
  • Battery Life: 12 hours on average listening, 24 hours in standby
  • Charge Time: 4 hours w/ original cable
I/O
  • Power Input: USB-C port, or charging cradle for charging
  • Controls: Top pad w/ buttons
  • Button controls: Power on, Bluetooth, volume, play/pause, microphone off, voice action button
  • Microphones: Microphone array for voice pickup built in top control pad
Bluetooth
  • Bluetooth Range: Up to 30 ft (9 m)
  • Bluetooth Version: 4.2
Water Resistance
  • Rating: IPx4 Water-resistant design
Compatible Software
  • Bose Music App
In the Box
  • Bose Portable Smart Speaker
  • Power cable
  • AC power adapter
  • Quick-start guide
  • Owner’s guide
Additional Information
Author
with
Max Kletskov
42,382 Reputation
16 Guides authored
Past 24 Hours: 1
Past 7 Days: 32
Past 30 Days: 134
All Time: 4,489
