Up to 20% off select tools
Potential Student Project
This page has been tagged for revision by students in our education program.
Student In Progress
This wiki is being worked on by hardworking students.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background: Information page:
  • The Bosch Dishwasher is conveyed by it's modular interface, users engage with this device by using the main control panel, with the appliance interior tools, this devices main feature is the fact that it has modular water settings for it's users.
  • The device comes with a water-softener application which adjusts the flow of water for its cleaning cycle. This is accomplished by the correlation of a monitored salt balance that needs to be introduced to the device in order to work, to a maximum of 1.5kg for the appliance.
  • There is a rinse aid container which converts ph certified water to ensure your items are not damaged in the cycle. This is adjustable to fit the needs of the participant.
  • You should include the following items when using this appliance, objects not listed here are found in the official manual: Glass, Plastic, Metal dishware, aluminum or silver, decorative items that are metal based might sustain potential damage or ware during this devices cycle period
  • This device is detergent viable, for approved detergent and soaps that are sold commercially, it's recommend that users not use liquid soap when inhibiting the washers cycle as this could potentially damage the internal components of the device.
  • This device is equipped with: A water inlet valve, washer rack wheel overseen by a chip, Drain hose, dishwasher gasket, inner seal and panel, detergent dispenser and silver-ware basket for cycles of cleaning.
  • The Bosch Dishwasher model SHV4303 is considered an older model it was manufactured as late as 2017 however, earlier models have been subject to heating issues, this device has been called for inspection by the CPCS once, if your device was made before the latest improvements contact Bosch directly at: 1-800-944-2904 for any questions
  • The Bosch Dishwasher was first introduced to the market in March 2000, since then its sold millions of units however eventually due to faulty internal systems the device was discontinued by its manufacturer, the last updated model in 2017 features an open panel, lid, basket and a modest frame that is capable of cleaning many different types of items, these items are listed in the official manual from the Bosch institution, an estimated 400,000 units were sent to corporate stores for repair when an internal fault with the heating springs caused substantial damage to existing units, this is what lead to the SHV4303 being discontinued however it's still a viable and very affordable choice for many customers who are in need of a dishwasher that is reliable.
Identification:
Look near the door frame of the application near the top, where you will see a sticker or plating that indicates the models subsequent number, if this plating or code is faded it's recommended to utilize a visual aid such as a light in order to reveal the specific coding.
You should be looking for the E-NR model interface number, the FD number which is the production Date and the Z-NR which is the unique number designated to your device.
SHV Model
Battery
Technical Specifications:
Bosch Dishwasher SHV4303 needs a standard 120-volt 60 HC electrical source in order to function properly.
15 AMP FUSE circuit grid for optimal function
Energy on average per cycle: 0.9 to 1.6 KWH
A custom filter
  • Economy Wash: 113-122 internal temperature of appliance, 30 minutes until complete.
  • Regular Wash: 130-140 temperature when using this setting, 3 hours in total.
  • Heavy Scrub: 150-156 temperature for standard cycle of appliance, 2.75 hours in total for this mode
  • Each cycle takes around 40 minutes up to a maximum of 3 hours in total, which depends on the mode being selected
  • The dimensions of the Bosch Dishwasher and its estimated weight consistency are (33 7/8)H/ (23 9/16) W/ (22 9/16) D, 88lbs meaning this would need at least the following parameters of space in order to not risk damage of the unit, which is:
  • Height 33 7/8 inches
  • Width 24 inches
  • Depth 24 inches of space for this unit
Additional Information:
BOSCH
AppliancePartsPros
Manualslib
Author
with
Matt Zieminski
50,484 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 124
All Time: 994
