Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
1772-6
Background
The Bosch Die Grinder 1772-6 is a tool used for grinding, sanding, honing, deburring and polishing metal surfaces. It is a pneumatic product produced by Robert Bosch GmbH. The die grinder functions through air pressure and can reach a speed of 25,000 RPM. The grinder is equipped with a 1/8" and 1/4" collet, and uses a 1/4" hose. The tool has a length of 5.8" and weighs 1 lb.
The housing of the Bosch Die Grinder 1772-6 is composed of glass-reinforced nylon known for its durability. The grinder also features a rear exhaust that directs air away from the workpiece and a feather throttle lever that provides control over the speed. The inline design of the tool allows it to be used in tight spaces. The grinder accepts 1/8" and 1/4" collets which allow the use of small mounted points and wheels for precision grinding and finishing work. The small diameter wheels and points, combined with the high RPM, enable detailed work on metal parts and surfaces.
Technical Specifications
  • Model Number: 1772-6
  • Product: Bosch Die Grinder
  • Product Type: Die Grinder
  • Power Source: Pneumatic, air pressure of 90 PSI
  • Speed: 25,000 RPM
  • Collet Capacity: 1/8" and 1/4"
  • Hose Size: 1/4"
  • Length: 5.8"
  • Weight: 1 lb
  • Housing Material: Glass-reinforced nylon
  • Exhaust Location: Rear
  • Control Type: Feather throttle lever
  • Design: Inline
  • Motor Power: 0.3 HP
Warranty
The Bosch 1772-6 die grinder is accompanied by a 1-year limited warranty. This warranty is specifically designed to cover any defects that may occur in the materials or the workmanship of the product. However, it is important to note that the warranty does not cover instances of normal wear and tear, misuse, or improper maintenance of the product. To claim this warranty, one would typically need to contact the manufacturer directly, providing details about the defect and proof of purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 340
